Just got new tires today balanced and aligned pretty well.
Two issues ive been dealing with the last few months:
1. Front shutter while braking after putting ebay slotted and drilled rotors on. Did i get screwed with warped rotors?
2. I also can hear and feel brake hardware moving around when braking. When i got down there and looked on the front i can shake the pads back and forth with slight movement. Isnt this suppose to be tight with no movement?
All hardware and pins are properly in place. Could it be my pins are wore down and not keeping things locked in place? My new pads are volvo I believe, could the pin not be making proper contact through the pad inserts?
Thanks
Thanks
