Did this back in November:
On Friday the 13th no less. Been debating having it fixed, then realized I only paid 300 for the car and the repairs would cost more than a suitable replacement.
Enter (possible) replacement... Found this one on Craigslist, 3.5 miles from the office, so the acquisition story isn't as eventful as some of ours have been. Rode the bus to the office today, had a friend drive me over at lunch and was back in time to eat.
P.O.'s pics:
Waxed a couple of test spots and she will shine like new money before long.
By far the cleanest interior of any of the cars I've bought recently. Also seems to be quite the cream puff for having 144k miles.
I bought it knowing it needed a head gasket, rear windscreen (cracked), a heater hose and the trim replaced on the rear/pass door.
Since then I've discovered that the speedometer doesn't work, the sunroof doesn't close all the way, passenger front window doesn't work, factory radio works, but the amp is not working (2 dash speaker audio system -woot!). Hood has cracked paint and the trunk has a nice dent on top. Needs cone bushings for the front end too.
Interior is as close to perfect as 18 year-old peanut butter leather is going to be. Tires are good. Started on the first try. Drives ok and doesn't overheat. Oil in the water though so the HG is coming shortly.
So the list thus far reads:
Replace amp (temp fix - already have 3 stock amps - until I decide if this is a keep or a flip).
Head gasket and all top end seals.
Clean and lap the valves.
Timing belt
Fix sunroof
Replace the door trim (already have some)
Hood/Trunk replacement - as the junkyard allows for them in the correct color.
If I decide to keep it, transfer over from my wrecked 940 wagon:
IPD sways
Pioneer head unit
Squirter block rebuilt motor(?)
Tethys and adapters
Intrax springs
Gauge-pod and gauges
Later:
R/C/R tails
Glass moonroof from 960
