Old 06-18-2017, 09:18 PM   #1
svxguy
svxguy's Avatar
Default Ac compressor interchangeable?
My 92 240 a.c. comp is done. I doubt any other models a.c. compressors are interchangeable. But thought I'd ask. I did see anything specific when I searched
1984 242 turbo sold to sweden
1988 740 turbo wagon white 300k
1992 volvo 240, 5mt flowmaster 17's Sold but bought back 3 years later . D.D
1986 volvo 240 beige - Sold
1994 svx luguna blue 03 wrx 5 speed. Totaled into a tree 😥
1994 svx black - Sold
1994 svx luguna blue -Sold
1992 svx pearl white -Sold
1992 svx Pearl white Junked
svxguy is offline   Reply With Quote
Old 06-18-2017, 11:54 PM   #2
nyalex
This interchange should get you close if you're off to a junkyard.
http://www.autozone.com/cooling-heat...43_102126_3515
The Seiko-seki is. I got mine off of a 93 940. It was the first one to come with factory r134a. The inlet and outlet ports on the compressor are angled as opposed to straight up and down, but I was able to get everything attached and working by moving one of the mount brackets on the compressor.
nyalex is offline   Reply With Quote
Old 06-19-2017, 12:20 AM   #3
white855T
You can grab an ac compressor from 740, 760, 780, 940 models up until 92. It will interchange with no fitment issues.
Buyer/Seller Feedback
Old 06-19-2017, 01:25 AM   #4
svxguy
svxguy's Avatar
Awesome thank you guys!!
Old 06-19-2017, 04:25 AM   #5
chevy_dude97
I don't think the compressor cares if it has 134 or 12 in it. It's all about the seals and the refrigerant properties. R134a does not like mineral oil, so if you have your system flushed make sure you use ester oil instead. Also note the capacity will be different between the two types. If you do a yard swap, pull the whole thing.(from a known good source) This way you know it has the "barrier style" seals. The old systems would leak under higher pressure, especially if you already had a leak.
Best bet? Find the leak, replace broken parts with like parts, refill with R12. As long as the system has not been opened, you shouldn't have to replace too many things or worry about a flush to remove any foreign particles/water that could wreck your compressor or freeze up your system.
1989 740GLE 8V 250K miles in Survivor mode
1951 Buick Super
1980 MG MBG GT Sebring
2001 Seat Alhambra 1.9TDI
chevy_dude97 is offline   Reply With Quote
Old 06-19-2017, 05:57 AM   #6
90volvo
If compressor died then it would be a good thing to replace condenser and drier. You can get new condensers cheap and drier are cheap as well. I was browsing and noticed that Duracool has brand new condensers on sale. Thought I would throw that out there if youre thinking about going that route.
Old 06-19-2017, 04:48 PM   #7
James10952001
IMO refilling with R12 is irresponsible, there's a very good reason R12 was phased out. I've converted 3 740s to R134a and it works very well, all of them with the original Diesel-Kiki compressors which I've heard are not great but zero complaints from me and a full charge worth of refrigerant is like 30 bucks.
James10952001 is offline   Reply With Quote
Old 06-19-2017, 05:22 PM   #8
Khrrck
Professional Amateur
And R12 is only going to get more expensive and harder to find.
'87 240 budget wagon.
Old 06-21-2017, 06:18 AM   #9
chevy_dude97
Sorry should have said R12a, which is pretty cheap and a direct replacement.
