- May 27, 2008
- Rockland County, NY
Thank you both for the valuable information on cooling system layout and the intake; cathedral port, 3 bolt TB. I'll look around for LS6 options. I'll stick with DBW - easier to keep stock cruise control functionality vs. adding cables & servo pods, etc., to make it work.
I'm wondering whether I will need to switch to the car version accessory drive (AC, PS, ALT) to gain that couple inches clearance for cooling system. That's a whole 'nother can of worms - there are so many variants it seems, bling aside (which I don't care for).
There are two types of intake port on the Gen III LS-based engines: cathedral and rectangle. The 4.8 LR4 will have cathedral ports which means only certain 'car' intakes will fit. There are two types of throttle body flange as well: three bolt and 4. The LR4 has a three bolt, which again means you need to use a specific car intake if you don't want to mess about with converting. The LS1 and LS6 car intakes are three bolt and cathedral port, so those are the ones you want to hunt for IIRC.
Mine was a truck motor too, an alu 5.3 LH8 from a Hummer Alpha. LS parts all swap back and forth pretty extensively, I think (talking Gen 3 and 4) the only thing you have to look for are the older 'cathedral' ports vs. the newer 'rectangle' ports.
Other than that I suppose there could be some oddball interferences between car intakes and truck accessories, and vice versa. In terms of front end accessories poking up where the lower car intake's throttle body needs to be.
My motor came from a front-crashed truck, I was pretty much starting with a blank slate, so I used Corvette front end stuff, it's is about an inch shorter (length, not height) than the car stuff (Camaro/GTO), and a couple of inches shorter than the truck stuff.
