- Mar 2, 2005
- Maryland
wd-40 turn her over start it up
I don't see any FOD, just water.
I have a block that's rusted like that from sitting inside after being in a junkyard for a month or 2 and wrecked in the wet. Learned the hard way, manifolds don't keep an engine dry
It mic'd 95.92 mm, the spec for a new piston of that size is 95.98-95.99 mm thats a difference of .054mm under the stock size or .0021" I haven't measured the bore yet. Any idea if thats excessive or if it will produce any problems?
carbon. it was the exh valves that were coated, not the intake. mikeP once said the coating was really thin. don't worry about the coating. wire wheel away the carbon, though.I started to clean up the valves and i noticed this,
Is that carbon on the left or the stellite coating? I dont want to remove it if its not supposed to be removed.
