Old 04-07-2021, 02:13 AM   #1
shaneo123
Default Performance Camshafts b230ET
Im after a new camshaft for my B230ET build, heres just a couple key points about the engine so far,
Holset H1C - 0.82 rear housing
Has A cam already
forged rods and pistons
all new bottom end rebuild
head has been port and polished (530) thats all
LS1 coil pack
Haltech 2500 elite
so i'm not looking for outright power its just a cruiser that has a bit of power when needed but im after a camshaft that will have a nice lumpy idle that is noticeable, i have looked at IPD and kgtrimning,
id like a camshaft that can be used in the head i have with minimum modifications such as shims ets does anyone have any idea where i could get a decent camshaft or recommend something to what im after?
im from Sydney Australia an hard to find anything performance related.
cheers Shane
shaneo123 is offline   Reply With Quote
Old 04-07-2021, 04:25 PM   #2
Bloody244
Enem.se has alot cams they also help find the right one for your setup
i have a v16t in mine it is alot of fun not amazing down low but at mid-top its amazing
1987 244 B230f+t @17psi 19t V16t cam Lite Ported 531 Head Stock Skinny rod Block Do88 intercooler Stock AW71
Praying for a window free block
Bloody244 is offline   Reply With Quote
Old 04-07-2021, 08:33 PM   #3
I have enem cams in my stuff and am very happy with them. If you want a cam like the enem V15 you could get the IPD turbo cam. But for your setup. I would get a V16 T cam. They supply new cams from blanks at enem so that is why they have a higher price than other suppliers.
Old 04-08-2021, 05:20 AM   #4
Leon_pp
love my KG2T from kgtrimning, great change from previous A
Leon_pp is offline   Reply With Quote
Old 04-08-2021, 11:43 AM   #5
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
I love my V15 Turbo. Probably the nicest "fun daily driver" cam you can get.
Idles pretty stock-like, though.
I sell chips for LH 2.4!
Old 04-09-2021, 12:00 PM   #6
Jussi Alanko
v16t is a good camshaft, kl-racings t3 is a good option.
Best route is this which i go for, and that is a full custom camshaft.
At least here in Finland, we have a lot of rallycars, and a Volvo engine is a very plentiful in rallying, we have those camshaft grinders who grinds you a custom camshaft at something about 120-170€, but you have to give a blank to the camgrinder, it had to be a,k,h or vx3.
First i send a cylinder head to porting specialist and tell which turbo i have and what i need from an engine, then he make head to me. Actually i say to head specialist that i need max power at 7200 and i need to have at least 210cfm at intake side.
Then he says to camshaft grinder what kind of powerband i need and what is my goals in power-wise. Then he grinds me a camshaft from a vx3-cam and i have 278 @ 0.050 and 12mm lift.
And when he gets my cam he installs it and shims it to 0.25mm to intake/exhaust.
If you have same kind of opportunity to regrind a camshaft, i absolutely recommed this option, But first your cam grinder needs to know your cylinder heads flow characterics, if your heads flow stops at 12mm, then you have no need to put a 14mm lift camshaft to it.
For example i needed a cylinder head/ camshaft combo, which is durable and had a good longevity. Then 210cfm is enough and this kind of goal you will have also good flow characterics at lower lifts, also flow speed in intake channels remains good enough to give a large register and good low rpm torque.
If you need a 255cfm flow for, let's say a 531 head with 48/40mm valves, then max flow goes to somewhere about 15mm lift, and if you need this kind of flow then you sacrifice some of the low rpm torque. And you need also a lot different camshaft, you need a solid 37mm lifters and very aggressive camshaft. This kind of cylinder head/camshaft combo gives you a very good hp figures and very rpm happy engine. But then you have to make a compromise at low rpm torque and also turbo spools less faster and also a little higher in rpm band compared to head which flows 210cfm.
So my long answer can be reffered to this: make your cylinder head first, then measure it at flowbench, and then you have max lift number to your new custom camshaft. Then you have to tell your camshaft grinder what you want, if you want a powerband like 3500-7500 your cam grinder make a cam for you that fullfill your needs. If you have a need for a powerband like 2000-6000rpm and a good low rpm torque, then you also can have a camshaft which is made just to yours engine specs, if you need an engine like this then for an example a-camshaft can be grinded to a "truck or torque" -camshaft, it will be a lot better than off the shelf camshafts because it was made just for you and your engine specs.
Jussi Alanko is offline   Reply With Quote
Old 04-09-2021, 12:57 PM   #7
DailyDriverMods
DailyDriverMods's Avatar
With a B230ET you already have a smidge higher compression ratio than a standard B230FT so you will have some more torque down low with a sportier cam compared to a FT. I have an IPD Turbo cam in my mostly stock B230F (soon to be +T) which basically gives max torque from 2.5k rpm all the way to 4.5k rpm and then tapers down again. The idle is relatively smooth as well.
dynorun
But with your Holset turbo you probably want a cam that is a bit more rev-happy, i think that a V16T would suit the powerband of your turbo much better, and it would probably give a rougher idle. We also had good luck with a KL-racing cam in the ITB engine but that was NA of course.
[1991 Volvo 240 sedan, daily driver ] [B230F|IPD Turbo Cam -2*|MS3x|145HP/215NM|M47]
~Gotta love that GL trim~
The excessive TD04 turbo guide ®™
DailyDriverMods is offline   Reply With Quote
