Old 04-07-2021, 03:50 AM   #1
SkeTchy-MechAniC
SkeTchy-MechAniC's Avatar
Thumbs up Dyno results NA KL-Racing T5 cam
Just finished dynoing the b230FB. The cheap camshaft performed way better than i could have hoped. It made for a really fun engine to drive since it pulls hard all the way to the rev limiter @8150 while still producing plenty torque at the lower revs. Idle is sexy too..
Build tread is hiding here somewhere, Specs are in there but shortly:
530
46/38
KL-T5
GSXR1000 ITB's
4-2-1 header
stock turbo rods
stock FB pistons
squirters
Never have i ever .... Seen a 242 with two motorcycles in the back
SkeTchy-MechAniC is offline   Reply With Quote
Old 04-07-2021, 04:16 AM   #2
JerryJS8
der Junge
JerryJS8's Avatar
Nice results!
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 04-07-2021, 07:04 AM   #3
Swedbrick
Swedbrick's Avatar
Sweet!
Volvo 745 - IPD springs, 25mm/19mm swaybars, K-cam, LH2.4, M90 swap, 3.54 \w racingdiff lsd, track/daily
Old 04-07-2021, 07:45 AM   #4
shoestring
shoestring's Avatar
This is a great result. Is there a before and after or is this the first go?
Old 04-07-2021, 08:27 AM   #5
esmth
i didn't know these lumps of pistons could go that fast
what was done to the bottom end, re-ring, hone, and a balance?
1991 244 LH2.4 M46 352k miles
Old 04-07-2021, 08:31 PM   #6
doucheNozzle
doucheNozzle's Avatar
I read 46/38 as the turbo size not the valve size.
Those are good numbers.
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'11 XC90 V8 - Torque Monster
Old 04-08-2021, 03:44 AM   #7
SkeTchy-MechAniC
neither did i
Bottomend is stock low mileage, Started off with the rev limiter @7k since my old b23e lived there all the time with it's heavy internals but the hp graph wass still rising, So moved it to 7.5, still didn't seem done so we had to know, And these engines have pretty stout internals so we took the risk and it payed off.
Spend 2 days on the dyno tuning it. At fist we had some ignition problems but that turned out to be a failing 0124 module retarding timing with rpm. After that most time went in the tune and cam settings. Cam ended up being just fine straight up.
Old 04-08-2021, 12:03 PM   #8
Nice numbers! The stock b230 bottom end is pretty darn stout, and the rally car spent a lot of time over 8k rpm with a completely stock bottom end.
I remember your ITB setup form some of your other posts, glad it's working out well! This really goes to show how restrictive the stock intake manifolds are, and that ITBs can still have good low end torque!
A few questions
Is this wheel horsepower or calculated crankshaft hp?
What CR did you finally land at?
Old 04-08-2021, 12:04 PM   #9
122power
dude
122power's Avatar
Nice!
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 04-08-2021, 12:07 PM   #10
1. They are not that heavy
2. 80mm stroke makes for fairly tame piston acceleration and top speed
PS, OP, looks like an awesome power curve. Congrats!
Old 04-08-2021, 05:43 PM   #11
Great job!!! That car must be a blast to drive.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 04-08-2021, 06:10 PM   #12
Way to go! That's a lot of fun in a brick.
Old 04-09-2021, 02:38 AM   #13
SkeTchy-MechAniC
Thankyou guys!
I'm verry happy with the results.
HP is crank hp and compression ratio should be close to 8.5 dynamic, I took a comparable catcams cam to do the calculations. Cant wait to drive this thing some more, But first have to finish it for MOT. Fuel used is btw euro 98 (5%ethanol)
