#26 |
Watching the World burn
![]() So do early Rabbits.
1985 Chevy TPI V8 740. ![]() |
#27 |
![]() That's fine. I've worked on some heads that needed 1mm removed from them since they had been rebuilt so many times. No issues with valve tip wear, you just need to check the spring pressure since the installed height is way different.
Cult Person. Pissing in your Kool-Aid. |
#28 |
![]() The last thing, I don't have a Dremel but I'm going to buy one to clean the surfaces. What material is best on the Dremel for cleaning the valve cover and the head? I don't want to damage anything.
My Feedback Thread https://turbobricks.com/forums/showthread.php?p=6141678#post6141678 |
#29 |
![]() Which surfaces are you planning on cleaning with a Dremel?
#30 | |
![]() Quote:
Power tools on aluminum heads tend to make thing un-flat and leaky. ![]() ![]() ![]() ![]() ![]()
1990 740GL, now in extra-small economy size. 511,000 km so far... |
#31 |
![]() Thanks for the tip. Didn't know you could warp things with a dremel.
#32 |
![]() Ok, so here my measurements. The first lines are my measurement with the stock cam still installed, then on the bottom are the measurement after installing the IPD turbo cam. It seems like all clearances increased a little bit. The only changes I made between measurements was swapping the shims on exhaust valves 2 and 4. Ignore that the paper says all measurements in mm. at the top and the grease all over the page.
I have read multiple sources that each list a different specified clearance so I want to make one more post here to get a final answer on correct valve clearance. Volvoclub.org says .3 to .4mm or .011 inches to .015 inches for a cold engine. The online Haynes manual says .014-.016. I've seen glesstr say .014-.018 in a previous thread as well. What is a final consensus? I'm currently leaning toward buying 6 3.80 shims and installing them on all valves other than cylinder 3 valves which are currently .016 which I believe should be fine as is. Maybe not, please lmk lol. ![]() |
#33 |
![]() When I am adjusting I aim for .015". The allowable range is wider when checking. It is something like .013" to .018" as the range of allowable clearances. Personally, I like to get the lash no larger than .016" all on a cold engine.
Dave, 1982 242 turbo. 338k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration. 1993 245 Classic, 430k miles, enem V15. IPD bars and chassis braces. Simons sport exhaust from Scandix. sbabbs ezk chip. Been a good road warrior. Genuine Volvo rebuilt leaky M47. ![]() |
#34 |
![]() Thanks, all I needed to hear. I think I'll go ahead and order six 3.80mm shims. Should be mint after this.
Thread Tools | |
Display Modes | |
