Old 02-06-2003, 07:55 PM   #126
JohnLane
[quote="NoSloVo."][quote:07b800e0e0]OK, I tore the Quaife gearset out last night.
... ok .. so 1st and 3rd gears are OK ... ... what else is good that isnt in the quafie kit for $1325?
thanks,
Oskar[/quote:07b800e0e0]
What is good is that you will get both sets of broken Quaife guts along with an M-46 case, already modified to fit the Quaife stuff. The M-46 has the very late model BIG mainshaft and the P-Type overdrive. The overdrive worked just fine, and I was never able to break the mainshaft. The gears would break first. Twice. You will get to supply your very own bellhousing, as I suspect that you will not be doing a V-6 project, and also that it is huge, and not worth the dough it would take to ship it. Now the big question has to be: "How much money should I demand for my old, unused, broken junk that is taking up space?" Keep in mind that my broken up old junk has sentimental value to me, but that I could be persuaded to part with these treasures for the correct amount of dough. So guys and gals.....Step right up!! Don't be shy!! I have some really fabulous broken junk that will go to the highest bidder.
Thoughts??? JohnLane.
Old 02-06-2003, 07:57 PM   #127
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
So have you got enough decent parts to hobble together one quaife m46? If you do I'm intrested!
Doug
Old 02-06-2003, 07:59 PM   #128
Anonymous
Guest
Getrag correction. The Getrag 265 has an overdrive 5th gear (i.e. not 1:1). The "dogleg" I-H pattern Getrag is the 262 CR (i.e. Volvo M51). The gearboxes look almost identical externally. The BMW E30 M3 came with the 265 here in the USA and the 262 CR in Europe. Also the M-B 190E 2.3 16V can with the 262 CR. Bimmerworld sells the 262 CR's for $1950 if anyone is interested in one. My BMW shop has several 262 CR's also (in England at a friends shop).
As for M45/46/47 gearsets. Quaife makes gearsets along with SF (I believe this is the company name). Most of the Swedes prefer the SF gearsets, as they seem to be slightly stronger. Contact the fellas at Valencia Volvo R-Sport for these gearsets. They have excellent contacts in Europe. Claes can get you the parts from the manufacturer not distributors like SAM (i.e. cheaper).
Quaife makes a quick ratio rack for the Volvo 240 along with their ATB (Bildon Motorsports sells the Quaife ATB for the 240 for @ $839). SAM used to sell one, not sure if it is still available.
David
russelldb@hotmail.com
Old 02-06-2003, 09:28 PM   #129
Guest
E30 M3's in the US DID come with CR boxes.
Sean
Old 02-07-2003, 04:06 AM   #130
oppositelock
Doug
4th gear from the other gearset is good, so the only parts that need to be replaced are 2nd gear and the layshaft.
-Dave Clark
John Lane's signature SHOULD read: "If more is better, then too much should almost be enough!"
oppositelock is offline   Reply With Quote
Old 02-07-2003, 10:39 AM   #131
Anonymous
Guest
Sean
Maybe a closer ratio Getrag 265, but definately not the Getrag 262 CR. I have an E30 M3 and it has a 265 with the H-I shift pattern. That goes for every E30 M3 I have come across and heard of, which matches the factory specs. All USA spec E30 M3's came with the Getrag 265 and a 4.10:1 final drive. The European M3's came with the Getrag 262 CR with a 3.25:1 or 3.15:1 (Sport Evolution) final drive.
Here are the gear ratios for the E30 M3 Getrag 265 and 262 CR
265: 3.83:1, 2.20:1, 1.40:1, 1:1, 0.83:1
262 CR: 3.72:1, 2.40:1, 1.77:1, 1.26:1, 1:1
Both of these gearboxes will fit in a 200/700/900 series car with the bellhousing adapter and modified linkage. You can purchase the linkage from Volvo (200 series only) or SAM.
David
Old 02-07-2003, 10:39 AM   #132
Hank Scorpio
Ok, it's alright anyways, I've decided I'm going with a t5 because I can ;)
Doug
Old 02-07-2003, 07:05 PM   #133
oppositelock
Just to get this thread back on track...
The Powerstroke intercooler install is nearly done. I started another thread with links to the photo album since this thread is getting a little long and bogged down. Go check it out.
-Dave Clark
Old 02-09-2003, 06:07 PM   #134
ELM
heres a pic of Johns car that my girlfriend took at the IPD garage sale... I need to also mention John was giving rides in AND letting people drive his car there... I was a fool not to take a ride, but I was stuck manning a booth and couldn't get away. John will you give me a ride at Thunderhill and scare the crap out of me???? please.
ELM is offline   Reply With Quote
Old 02-12-2003, 12:03 PM   #135
JohnLane
Hey Guys and Gals.
the P/S intercooler is in, all the facia is back in the car, and the holes where the 'Merikanski spec rectangular high beams are going to just make for more airflow to the intercooler. All that is left is to come up with two hoses to get from the pipes to the intercooler. That will happen today. Now if I can manage to get the front wheel bearings fixed up, I will play with it at the rallysprints this weekend in Hoqium. Holding my breath. JohnLane.
Old 02-12-2003, 03:27 PM   #136
Volvo78GT
American sucks dont it John?
if you dont know what I'm talking about, we're talking about american spec headlights... even the best sylvania x-tra vision non-replaceable headlights suck totally compared to true euro-spec. They just glare too much and dont illuminate. I cant imagine what it'd be like rallying with american spec headlights! talk about braking too late! There is a reason why people overload on the fogs and drivng lights (which only contributes to the glare...) so those driver can actually see some light on the road...
Volvo78GT is offline   Reply With Quote
Old 02-12-2003, 03:28 PM   #137
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
Decided against the 7" round John?
-Kenny
Old 02-12-2003, 07:44 PM   #138
JohnLane
I have everything to do those, but am too lazy to do the flat hood and such. This is easy, and at this point in the game easy is sounding very good indeed.
I am told that the wheel bearings are happening even as we speak.
The silliness will commence soon. 8) JL.
Old 02-13-2003, 01:03 PM   #139
JohnLane
Oh......For night stages, the Volvo uses four Hella 'Rally 4000 motorsport' HID driving lights mounted up on a lightbar. The two lamps that are 'missing' were there only for cosmetic reasons anyway. With four HUGE HID lights, I make DAYLIGHT for half a mile in front of me.
As it says......."Overkill is consistently more fun." JL.
Old 02-13-2003, 06:08 PM   #140
oppositelock
Originally Posted by JohnLane
[quote:839c703869="CaptainBondo"]Decided against the 7" round John?
The silliness will commence soon. 8) JL.[/quote:839c703869]
As a matter of record I think John has used every version of headlight Volvo ever offered for the 240 at some point in the Fire Breathing Monster's life. And it would suck to go back to the flat hood because the current hood has all the cool vents and scoops for the turbo and if he went to a different hood that means I would have to paint more flames. I've already had my fill of right front fenders!
-Dave Clark
Old 02-13-2003, 10:46 PM   #141
JohnLane
-Dave Clark
You stand corrected Dave. I have not had the European Flat hood lights in my car, or the European turn lenses which would be smashed into a tree in the first rally I would run them in.
But I did have the European lights (with wipers!!) which I smashed up real nicely at first. At one point I went off the road and one of the Euro lights fell out so that I could run over it. It was returned to me by a concerned sweep crew looking rather flat. JL.
Old 02-19-2003, 02:52 PM   #142
JohnLane
Hey Guys and gals.
Just got back from driving the Volvo with the Powerstroke intercooler, the new front wheel bearings and the DMS rear shocks for the first time.
Oh Dear!! Boost comes up FASTER, smoother, and more predictably.
Perhaps I had a little more pressure drop across the intercooler then I thought? Hmmmmmmm............ The shocks REALLY control body motions without being harsh. Hmmmmmmm............
JohnLane.
Old 02-19-2003, 02:54 PM   #143
Captain Bondo
"Boost comes up FASTER"
I had the same experience. Imagine that. Naysayers crack me up.
Congrats on the successful test run bro.
Old 02-19-2003, 03:03 PM   #144
bitjockey
[quote:b335d770d5]Oh Dear!! Boost comes up FASTER, smoother, and more predictably.[/quote:b335d770d5]
But its still just TOO BIG to be effective!!! Overkill!!! Blah blah blah...
I'll attribute it to your new wheel bearings... 8)
Originally Posted by isaac
Shame costs more than a 13 second Volvo.
bitjockey is offline   Reply With Quote
Old 02-19-2003, 03:57 PM   #145
Volvo78GT
Are you saying its coming up too fast?
LOL I had to.
Old 02-19-2003, 04:10 PM   #146
WeezilUSA
WeezilUSA's Avatar
How could it be too fast?
1983 242 ICSCC GP Race Car
WeezilUSA is offline   Reply With Quote
Old 02-19-2003, 04:15 PM   #147
Volvo78GT
Heh.
Jason goodley has his boost coming up too fast... 16psi by 2500RPM... full 22psi+ at 3200RPM... talk about a hard car to drive if you dont have 100% dry road. He was telling me about one day that he got stuck at work (Volvo of Dallas) with his "race" car and it was absolutely pouring out. His car is setup to boost very quickly and thus he took a 30 minute drive (sanely) in 1.75 hours... its a drivability issue. LOL.
Thats one of the problems when you develop a extremely fast car is its drivability. Its a balancing act. I aint saying it cant be done, but there's always a risk about blowing something out or bending the chassis (LOL) or having or traction or whatever... just set up the car right, to your expectations and it will be fast in the conditions that its designed for.
Tires, gearing, handling, ride, boost control, blah blah blah all have impact on drivability.
Oh yeah, last time I saw him he was moaning about he couldnt drive his car because he blew the axle to pieces... LOL
Old 02-19-2003, 04:15 PM   #148
Captain Bondo
The only person who would ask if it's too fast is someone without a turbo. ;)
Old 02-19-2003, 04:16 PM   #149
Volvo78GT
read above post.
Old 02-19-2003, 05:27 PM   #150
Captain Bondo
You need to talk more about things you actually know about.
It's 700hp rallycar with a HUGE turbo with JOHN driving it for one thing... and you're going on about driveability? WHat planet are you from again?
Your friend either needs to learn what part throttle is or buy better tires. That sounds like a bunch of BS to me. Or get a larger A/R exhaust housing which if it really were boosting "too fast" would give more top end and cure his "problem". You'd get it if you had driven a turbo car at all. But you don't so really it's a lost argument. If you new anything about turbos, well, lets say its obvious you don't.
Some days I wonder if Steve C was right way back when...
