#26 |
weapon of mass detonation
![]() tru dat. especialy if you are in search of a certain color. +t/LH is way cheeper and easyer that a respray
91 940 SE, 119K, GOLD 03 540i M sport 6 gears of go! 200k, White 05 S80 2.5T, RED 09 XC70 3.2L, BLUE 10 335xi, (fun has a price), black 17 expedition El, (short bus), black 85 RX-7 GSL SE(efi'ed), BLACK 76 Suzuki RE5, BLACK |
#27 |
![]() Hey Mike, have you looked into this any further? I pulled the LH harnesses out of my wreck today and after doing so I'm very interested in not swapping harnesses on my regina car!
#28 |
unbalanced chemical
![]() Join Date: Jun 2002
![]() If you have a harness you can swap just the wiring on the strut towers.
I will look into more and try the swap in a month or so when I swap trans on my Regina car. |
#29 |
World's Oldest Brewery
![]() This would be a great sticky to have someone do....ala the 240 Chrysler to Bosch swap.
My 93 945 is Regina....part of a Bosch harness is due to arrive tomorrow - once all is collected (harnesses, flywheel, ECUs, K-1 for the bullet heater, rum for me, etc) , mine is going 2.4 (FTW)....the hard way - everything from the fuse block on is being swapped - along with a nicer dash, etc.
![]() (IF YOU WANT ME TO LEAVE YOU FB AFTER THE FACT, JUST SAY) Alcohol does not solve any problem, but then again, neither does milk
#30 |
![]() i just spent an hour or so looking at the wiring diagrams, my brain is scrambled and it looks like a pita. ignition dosent look to bad but the fuel side looks crazy. altho it dose look like it wouldnt be hard to convert to the powerstage and get away from that dam crazy coil
#31 |
unbalanced chemical
![]() As soon as I find my book I will post up the wiring diagram as everything is wired the same, only different is Map / Amm and then coil/coil
#32 |
![]() This is easy I did it for a customer, I have the wiring diagrams on alldata and the Volvo manual wiring diagrams
if anyone needs them PM you're emal. |
#33 | |
![]() Quote:
I've got a matrix in excel that lays out the ECU pins Bosch>Regina and the EZK>REX, pin to pin what goes where and whether they are different or same. We are working on some step-by-step instructions as to what needs to be moved where etc. Just to give you an idea, from my first run through we found: for the ECU's there are 24 connections similar, 18 different. For EZK/REX it's much closer ~22 same, 4 different. I would upload the matrix to google docs but I'm at work, anyone who's interested send me your email and I'll send it to you. Mogly, sent you a pm would be interested in how you did it. Last edited by Stiggy Pop; 04-15-2013 at 10:14 AM.. |
#34 |
![]() yeah, definatly not a afternoon job. i could see doing it in a weekend after getting a plan of attack on the wires but. the lh system i hav is out of my 740 turbo, will the lack of the wot wire make things run funky?
#35 |
unbalanced chemical
![]() Ok so tell me what I am seeing wrong
LH http://thelostartof.net/IMG_20131103_044558.jpg Regina http://thelostartof.net/IMG_20131103_044646.jpg For LH pin 17 from EZK goes to pin 1 of LH pin 8 from EZK goes to pin 25 of LH pin 4 from EZK goes to pin 28 of LH For Regina pin 17 from Rex goes to pin 1 of Regina pin 8 from Rex goes to pin 25 of Regina pin 4 from Rex goes to pin 28 of Regina As for Map vs MAF looks like those wires are used for those things only so I just have to wire the correct pin to the correct location. Rex vs EZK all of the pins on the left go to the same spots as EZK on the left, same on the right also. I am seeing a lot of stuff matching. So someone show me points where it doesn't seem to match up as my brain is playing tricks on me I guess. Besides swapping flex plates, and then rewiring the Map to a Maf and coil wiring . . . . |
#36 |
![]() Pretty sure LH2.4 still fires when it wants to, regardless of where the distributor rotor is.
2003 Volvo XC70 ![]() 1991 945GLE - 16v Wagon! (in pieces) 1990 245 - DD, Pepper-thing (car, wagon, boat, mobile) - K-cam'd and Dale-gear'd - now an actual fridge, probably 1987 760 Turbo Intercooler - dead 07/14/2011 Feedback Thread |
#37 |
![]() PM me your email so I can send you my file.
I saw the following as different between Regina and LH ECU's: 3 6 7 8 9 10 11 14 15 20 21 23 28 29 33 I THINK we mapped it out pretty well, may save you some time. Still looks doable, I just haven't had time to really think about it since I tried to size it up. |
#38 |
![]() call me stupid, but what does "LH" mean?
#39 |
![]() Shorthand for Luftmasse-Hitzdraht (Seriously). It's a version of Bosch's Jetronic engine management that uses a hot wire Air Mass Meter.
#40 |
#41 |
BRANDSCHUTZVORSCHRIFTEN!
![]() Join Date: Dec 2002
![]() do you have an airflow meter on the airbox? or do you have a little two wire sensor on the airbox?
"They bum rushed them in their own crib, they drank all their beer, they partied with their ladies and they left with the trophy" Now with in-house Dyno tuning! Megasquirt Tuning! Plug and play LH 2.4 Megasquirt, now with stealth mode! |
#42 |
![]() Zombie thread...... How far did we get on this guys?
'90 Spec Miata.. The barbie car I never got as a kid..... http://norfolkdustlessblasting.com/ ... Professional stripper... |
#43 |
#44 |
![]() Roger that. Seems like Thelostartof was trying to get around swapping the whole wiring harness. Obviously that would be optimal. Looking at the schematics he put up there isn't "much" difference. You seem to think there's more than meets the eye...
#45 |
unbalanced chemical
![]() Lacking time.
But on paper it really looks easy as just a few wires should be all that is required to make it swap. Ezk and ecu swap and then a few wires in engine bay and then sensors. Maddest part of swap is the flywheel/flex plate |
#46 |
![]() good luck! i looked at the scematics for a few days, looked like more than that. hope it works out tho.
#47 |
#48 |
![]() To be honest I haven't really looked at my car real hard to get an idea of the Regina harness and connections. If I come across an LH2.4 set-up I'll get more serious. I've rewired a couple LS harnesses. So I'm used to the headache you get from looking at these schematics for an extended period of time. I guess if I get motivated, I'll post up what I end up doing.
#49 |
![]() hell, come pull the 2.4 harness out of the 740 im gonna scrap. ill donate it to a worth cause but i aint pullin it
#50 |
![]() Join Date: May 2007
![]() Better to just pull a 240 harness. Soo much easier.
