Old 02-07-2021, 09:43 PM   #276
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
More paint
Removed the Rad/Fans/AC condenser to replace the damaged condenser
I'd like to have added a Volvo fan - but just no room to make it work
Cut slots to add side vents like a Volvo setup (took the flaps from my old V70 fan shroud)
New condenser attached
Adding a VW two-temp fan switch
Need to add a another fuse/relay panel up front to run the headlights, fans, etc.,
Old 02-16-2021, 10:52 PM   #277
lookforjoe
lookforjoe's Avatar
Been working on the rad/ AC cold. install - I decided to revise the layout after I found a posting from another X1/9 where they tipped the rad backwards to alleviate the fans pointing uphill into the back of the tub. I can't go as extreme as in my case the AC condensor & 3" rad core prevent the same degree of offset.
Normally the rad leans forward - following the nose rake - now I have it about 6" back. Added an angle bracket at the top to locate it whilst I rework the rad support
Started cleaning up all the wiring - going to use a Volvo 900/850/x70 fan relay
chopped up some 700 ancillary adjuster arms & used the sleeves & 1378153 bushings to isolate & mount the support at the required angle
in place
welded some 3/8 stock to the rad base & threaded about an inch
bushing to isolate rad some more
Rad didn't want to align with evenly spaced brackets - determined the rad was tweaked in the accident - so I bolted a couple 6' angle iron to it & tweaked it back
test fit - had to cut the lower hose due to the increased distance
fans now sit at half below the floor line & point downward compared to original layout
made seal attachments to close off gap above & below rad
riveted seal support brackets once I got the precise location figured out
then paint
just have to finish up the fan shroud mods to compensate for the revised offset
Old 02-26-2021, 10:12 PM   #278
lookforjoe
lookforjoe's Avatar
Did some cleanup on the shroud, and also I added a locating tab - since I removed the lower frame section of the shroud the bottom edge is no longer rigid.
Started on the wiring for the fan circuit - I'm leaving all the stock wiring intact unused, except for the AC-on trigger. The Volvo relay will go under the molded AC hose/wiring cover. I'm moving the headlamp relay mod under that cover also.
although I have the big ugly fuse breaker & Honda ELD, I really don't want extra wires running over by the battery or over to the wiper relays, so I ran new wires crimped with the fusebox supply cable, in through the bulkhead & back out into the trunk following the stock harness. I used heavier (than the Fiat) gauge Volvo wires - to make sure I don't have load issues. These will be the fused 30 supplies to the headlamp relays, wiper relays, cooling fan relay, and something else I've probably forgotten at the moment
Tidied up the new wiring (constant feeds) to the fuse box, wired the two headlamp relays & the cooling fan supply relay, and added 2 switched feeds .
Plenty of spare fused circuits should I need them. So far, every time I thought I was done, I needed more circuits.
Added 2 M6 rivnuts for relays, cooling fan/sensor grounds - one for power (fan) grounds the other for sensor/relay coil
Fuse panel will go under here, eventually. I have to fix the inner fender / strut reinforcement behind it first - I was going to leave that until next year
Weather-proof connectors finally came so I got the body-side fan connections in place
Yazaki 58 series
VW fan switch connector & boot in place
For the larger ground connections I had to buy yet another tool - I have a hydraulic crimp tool, but that is only for closed barrel type, not 'open barrel'
Cut holes for tub vents / brake ducts - I'm keeping it non-structural, so no cutting of the frame rail. Using readily available ducting. 3x4 rectangle fits between the frame.
Old 03-07-2021, 10:55 PM   #279
lookforjoe
lookforjoe's Avatar
Cut out the right side ducts
ducts bonded in place
wiring to fan sensor done
sidetracked with some rust repair - I was going to leave this for another year or so, but I need to do it now
cut out driver's side rot
removed & cleaned up the rot off the brake line brackets
templates & cut repair sections
test fit
left side mostly done
right side tacked
Once these are finished, I have to add reinforcement plates from the strut housing back down the lower frame rail - chopped up a S40 bumper bar to use for that
Once this is done, I can get back to finishing the wiring, get the rad back in, then get the HVAC & dash back in....
Old 03-13-2021, 11:34 PM   #280
lookforjoe
lookforjoe's Avatar
Got the repair panels all welded after this
and added the reinforcements cut from the S40 parts car bumper
primed, caulked & painted ready for stone chip & undercoat
stil have to do cleanup on the inside
figured out the brake line brackets
made a bracket to mount the relay/fuse panel - cut up a V70 AWD fuel filter bracket
tub area done
Old 03-19-2021, 07:40 PM   #281
lookforjoe
lookforjoe's Avatar
Got sidetracked with replacing the DP flex coupler on my C30 last week - royal PITA with the AWD conversion
After that, got the stone chip & undercoat done in the wheel wells
Brake line retainers installed - put rivnuts in the skin & used torx machine screws
struts & brakes back in
Reworked the #8 hose to the condenser, required a #8 FOR 90º elbow due to the rad/cond re-alignment. I'll work on the #6 hose to the evaporator soon
ran the hose along the rail instead of along the water pipes - since the dogleg end of the stock hose is gone
The other end, I had to cut & splice a new section where the original was sliced in the accident
#8 straight MIOR was needed here to attach to hose running to compressor.
#6 line with orifice tube figured out. Then removed & crimped line fittings.
Fuse panel installed.
made a bracket to retain the fan relay to the inner fender
Check everything fits. I'll have to rework the carpeting for the frunk around all this
Old 04-07-2021, 09:59 PM   #282
lookforjoe
lookforjoe's Avatar
Put the HVAC back in, finished the floor stone chip & undercoat
Added a Volvo chime relay to use for 'lights left on' warning
Had to repair another rust hole in the d/s cowl - probably what caused the floor rot
Then dash back in
Finished the brake ducts
fan shroud & hoses back in.
Speakers from the S40 mounted in the kick panels
