Prius Owner
![]() Join Date: Jul 2008
![]() Ive been battling pedal feel issues for a few years now since I've put the brakes on. The first motion of the pedal I have nothing, maybe a little braking then I start to get braking. I get full brakes at the very end of the pedal movement. Ive tried a few different known good boosters, tested with a mittyvac pump to check of leaky seals and Ive switch over to the mustang master cylinder.
Generally I dont complain in dry condition, I have great breaking other then the pedal feel. When its braking in the wet, tires just lock up, same ****ty pedal feel or lack of pedal like in the dry condition then brakes just lock up unless you gingerly apply brakes. What are other peoples pedals feel like with the R brakes on the front and the mustang master?
93 245 LS Engine Swap Project |
![]() what bore master does the rb use?
unbalanced chemical
![]() Join Date: Jun 2002
![]() So you had the same issues with the stock old Volvo MC and then a new Mustang MC?
#4 |
Kapitän Klugscheißer
![]() Have you already played with the pushrod adjustment?
#5 |
![]() What is the piston size(s) on the calipers?
John Vanlandingham/JVAB Imports Sleezattle WA, USA --> CALL (206) 431-9696<---- www.rallyrace.net/jvab www.rallyanarchy.com Vive le Prole-le-ralliat "When a man tells you that he got rich through hard work, ask him: 'Whose?'" — Don Marquis |
#6 |
Been here for too long
![]() Leading Piston Size: 42mm (2 of each)
Trailing Piston Size: 38mm (2 of each) REAR BRAKE CALIPER PISTON DETAILS: Leading Piston Size: 28mm (2 of each) Trailing Piston Size: 30mm (2 of each) I found this on VIVA's site.
80 242- 2.5L 16V, NIW intake/exhaust, T5, Porsche brakes, short billies and Kaplenkhe suspension, Trutrack. Project Thread- http://www.turbobricks.com/forums/sh...d.php?t=324470 |
#7 |
![]() i would start with what the volvo r used for a master cylinder, what bore for what your using power/no power assist, then check pushrod, then pedal ratio, when i put the big brakes on my Chevy all of these things bit me in the ass, and a used hydro- boost that was slowly applying the brakes when it was running
#8 | ||
Prius Owner
![]() Quote:
Yes, but this has been in the back of my head. Quote:
#9 |
![]() do you have a build thread on the brakes?
#10 |
![]() If you're adjusted fully outwards and it's still not enough, here's what Marv did (Similar to Homer when he ran the Porsche Calipers IIRC). Do note that Marv is running the Cadillac ATS style Brembo calipers on the front of this car(wagon), though. I figured it's worth mentioning before getting further into the system and having to deal with bleeding the brakes a few times.
#11 | |
Prius Owner
![]() Quote:
#12 |
![]() Ah, word. I'm pretty much just echoing what freevolvos is saying though so, cheers. Unfortunate that the problem may lie deeper.
#13 |
![]() I realize many of us are asking 'problem obvious' questions....but, here we are. Did you bench bleed MC's when you replaced them?
'82 242 6.2L; '17 Mazda3; '16 CrossTrek |
#14 |
Who engineered this?
![]() The rod length is important to get right. If you haven't you need to replace the adjustment screw on the end of your brake booster rod. The stock rod isn't long enough to work with the mustang master.
#15 | |
Prius Owner
![]() Quote:
Yes |
#16 | |
![]() Quote:
![]() But EVERY progressive piston caliper---and those sizes are common as hell, and perfect--but I've already been banned like 3 times by that guy Mr Super Nice Guy up there in your neck of the woods just on piston sizes so I won't say more about that---- EVERY progressive has smaller piston FIRST...because as a n AP Racing injur-near once siad "First piston gets a nicer "bite" on the disc with longer pads so 1.5" first, then the trailing at 1.625" Always ![]() |
#17 |
![]() let us know if you get this figured out I'm interested in what causing the issue
#18 |
Prius Owner
![]() We did the math and we think I that I bought the wrong bore size mustang master cylinder comparing the stock 240 one vs. the s60r/v70r the one I have is too small so I've ordered a 1-1/16th inch bore.
#19 |
![]() the smaller the bore the higher the pressure in the line, i hope this solves your problem, a lack of fluid Volume sure would cause a lazy pedal to and i would think a high pressure situation would cause grabby brakes, low pedal
#20 |
All the gauges
![]() I've had no pedal issues with my r brakes all around and mustang master
![]() I will say my pedal is a little touchy. Not lock the brakes up touchy, but someone that hasn't driven the car will find the pedal sensitive.
Kyle and the "Projects" -- '84 242 TI -- '66 220 S -- '60 Coupe DeVille -- '84 Rabbit GTI ![]() |
#21 |
![]() Same experience. Ended up switching to the earlier, smaller, single-diaphragm booster and think it is just right with the mustang master and caddy calipers.
#22 |
All the gauges
![]() Do you know approx what years I should be looking at for this?
#23 |
![]() I got mine from Rockauto, A-1 CARDONE 535890, that was for a 1977 240. Looks like they are currently out of stock though. Maybe one of the fellas that services the wanted adds on here will have one on their shelves?
#24 |
Prius Owner
![]() Mine is the opposite of that. I have the new mustang master here with the bigger bore but have yet to install. Im still in the middle of a custom wooden barn door build. Hoping to get to the swap in a few days.
#25 |
![]() When I tried using a larger that stock master cylinder (Ford F-Series) on my 88 765 with Jumbo brake upgrade the brake pedal was nearly impossible to press, the pedal was rock hard. I installed a 2000 Ford Ranger master cylinder with 1.0625 inch bore and it was a good option. A 1/16 inch difference in bore size makes a huge difference. I also learned that the 700/900 cars with Jumbo Brakes used a brake pedal with a different ratio. So matching the brake pedal ratio to the master cylinder is a good idea.
Trying to understand stupid people is like trying to pick up a turd by the clean end. |
