Old 09-14-2018, 11:21 PM   #26
Texas240
Prius Owner
Texas240's Avatar
And now the results:
I am at fault for both issues. I clearly did my math wrong on the extension of the push rod, it was about 15mm short and I bought the wrong master cylinder. I bought a SVT when I should of bought the GT one. All is fixed and brakes are great and feel the same as they did when I bought the car back in 2007
93 245 LS Engine Swap Project
Old 09-15-2018, 04:57 PM   #27
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Glad to hear that man, I'm sure you're happy it wasn't something more labor intensive.
When available could you please share the part number for the GT Master cyl you purchased?
Old 09-15-2018, 07:33 PM   #28
Texas240
Prius Owner
Texas240's Avatar
Been bugging me for about a year now. I wish the 5mp and under squeal would go away.
The part I bought is a Dorman M390185 LINKY
Old 09-16-2018, 11:57 AM   #29
stick70
All the gauges
stick70's Avatar
Hell yeah, good to hear man.
Kyle and the "Projects" -- '84 242 TI -- '66 220 S -- '60 Coupe DeVille -- '84 Rabbit GTI
Old 09-17-2018, 07:02 AM   #30
2barxr
is this a full Volvo R brake swap Front/Rear?
Thanks for the info i am putting S60R's on my 91 940
2barxr is offline   Reply With Quote
Old 09-17-2018, 07:31 AM   #31
RoadRacer4Life
Owner: DeathWagon
RoadRacer4Life's Avatar
Its always nice to find out when the problem is actually solved..
90 245GL 2JSWEDE 2JZ 245...
91 245GL Team Battle Wagon Chumpcar
93 245GL Street Beater
Old 09-17-2018, 10:09 PM   #32
Texas240
Prius Owner
Texas240's Avatar
This was just the fronts. I didnt see the need to go rear also.
Old 09-17-2018, 10:10 PM   #33
Texas240
Prius Owner
Texas240's Avatar
For once
Old 04-01-2021, 02:46 PM   #34
rijk
rijk's Avatar
Originally Posted by stick70 View Post
I've had no pedal issues with my r brakes all around and mustang master
I will say my pedal is a little touchy. Not lock the brakes up touchy, but someone that hasn't driven the car will find the pedal sensitive.
Originally Posted by Marvelous3 View Post
The rod length is important to get right. If you haven't you need to replace the adjustment screw on the end of your brake booster rod. The stock rod isn't long enough to work with the mustang master.
Have R calipers f/r in my ’93 960 sedan with 330 mm R-discs, stock R brake pads with Mustang MC including rod extension. Together with replacing the MC the rod was extended. So what symptoms occur when f.i. the rod is just too short. The brakes are pretty touchy. Slowing down by just touching the brake pedal instantly activates the safety-belt locks. Took some time to get used to that at first. But on the other hand when I brake firmly at around 60 mph, the braking effect is only average. At a certain point deceleration does not increase when the pedal is pressed even harder. The brake force remains the same. Locking the wheels is absolutely impossible, far from triggering ABS. Dangerous situation. Vacuum issue? Using Chrysler E-throtltle. No leaking tubes.
The B204FT to B234FT conversion
http://forums.turbobricks.com/showthread.php?t=182821
rijk is offline   Reply With Quote
Old 04-02-2021, 05:22 AM   #35
rijk
rijk's Avatar
Default Anybody
Anybody familiar with this lack of braking power after converting to the V70R brake system?
Old 04-02-2021, 05:17 PM   #36
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Honestly sounds like the pushrod is set to long.
Old 04-02-2021, 05:25 PM   #37
Sounds like brake pad knock back to me.
@rijk, make sure to clean your hub surfaces and that there is no runout on your brake rotors.
Old 04-03-2021, 05:15 AM   #38
rijk
rijk's Avatar
Thanks. I'm going to check that.
Have left nothing to chance: Meticulous revision of all four calipers, new R-pads, new R-discs, new hubs, new SKF wheel bearings. No runout, non abnormal pedal feeling.
I am open to other suggestions.
Old 04-04-2021, 09:49 PM   #39
DrZiplok
DrZiplok's Avatar
Pad knockback won't give you those symptoms. What pads are you using? I hate to ask, but did you make sure they were in the right way around? What you're describing is exactly what I'd expect if you have the pads inside out...
Ignoring the stupid question, have you bedded the pads / rotors yet?
If the calipers were junkyard parts, did you check that the pads move freely? It's not uncommon (I have bought ~ a dozen of these so far) for there to be corrosion behind the steel pad-stopper plates in the caliper; this can result in the plate being forced inward and blocking / cocking the pad as it moves towards the rotor. Likewise did you verify that all of the pistons move freely? I've also had more than a few arrive with pistons siezed in the bore due to corrosion.
DrZiplok is offline   Reply With Quote
Old 04-05-2021, 06:07 AM   #40
rijk
rijk's Avatar
OEM R pads. No fancy stuff.
With inside out you mean the friction material is facing outwards instead of towards the disc???
I ignore that question :-)
If the calipers were junkyard parts, did you check that the pads move freely? It's not uncommon.
No junkyard parts. Bought second hand from reliable party. Although in good working order all four calipers were overhauled for safety reasons with new OEM parts (pistons,seals etc)
Old 04-05-2021, 11:13 PM   #41
brickcupra
Default brakes !!!
Hey guys , well my situation was different. I swapped a 7mgte into my 240 wagon and the original brake /booster system would not fit ,so I had to do some searching and after 2 years my brakes would almost take my teeth out. The booster is corolla, the master cylinder after 3 different ones ended up been a Lexus ls 400 1 1/16 bore diameter. The abs pump is out and the proportioning valve is from a Honda, the front brakes are a combination of Infinity I 30 rotors with re-drilled hubs with trailblazer lugs, the calipers are custom fitted twin pot Subaru WRX rebuilt by me with Nissan maxima brackets and Suzuki SX4 brake pads with Nissan Altima rubber hoses. Rear brakes are factory. The Infinity / Subaru/ altima/ Maxima brakes are compatible because they are all made by Tokico. It does the job for me. Ok JUst food for thr soul
Seeya
DZ
brickcupra is offline   Reply With Quote
