#76 |
![]() @smoothdurban
Thanks for the pics. It is encouraging to know that you didn’t need to cut the tunnel...this may be added to my winter project list. |
#77 | |
I do my own stunts
![]() Quote:
May I also add that I didn't need to shorten my drive shaft either.
1983 242 Turbo w Tremec T5 154,000 km's B230FT LH2.4 2019 VW Golf R w 6 Speed w 2020 kms NEW DD @smoothdurban on IG |
#78 |
Redblock for life.
![]() Quote:
#79 |
![]() @smoothdurban
What’s the approx diameter of the 4-cyl damper? Also with the tail of your transmission as low as it is, did you have any issues with firewall clearance at the back of the cylinder head? Last edited by oldschoolvolvo; 12-14-2020 at 08:50 AM.. |
#80 |
![]() I'm doing my T5 swap right now and everything is pretty much ready to go in the car. I still need to buy my slip yoke and was wondering if the big dampened 4 cylinder yoke would fit in a 740 tunnel? If not how does one modify the tunnel? Is it as simple as bashing it with a ball pein hammer? It seems that most people T5 swap 240's. I'm trying to do as much research as possible before I buy anything to avoid as many vibrations as possible. After reading this thread and getting feedback from other members my plan is to use the 4 cylinder slip yoke and two-piece driveline. I'm using Yoshifab's stage two clutch kit with the sts machining 20-pound flywheel and Yoshifab's 740 T5 transmission mount with a poly bushing. I will also do my best to get correct bellhousing alignment and correct u joint angles, although I'm not sure how exactly to go about that. My T5 was just professionally rebuilt by Jeff from Elite Performance near Portland and I'm using the Dee works kit.
#81 |
![]() Join Date: Oct 2004
![]() What was the part number for that yoke? I am pulling the trans in mine soon, so I will have the shaft out anyway.
RIP Doug Williams "Mr. Doug" 4/15/2009 Pete Fluitman "fivehundred" 7/14/2013 Mick Starkey "TrickMick" 1/10/14 Mark Baldwin "blue850t5" 7/19/18 Nick Fengler "fengler" 8/6/18 Thomas Fritz "stealthfti" 10/11/18 74 144 B20 http://forums.turbobricks.com/showthread.php?t=224983 90 745Ti http://forums.turbobricks.com/showthread.php?t=334698 If you need Superpro bushings PM me for price and availability! |
#82 |
I do my own stunts
![]() F6ZZ4841BA for the yoke and I needed a Neapco 1-0134 U joint.
I didnt pay $180 for mine either it was cheaper at Shaftmasters in Detroit but I think I grabbed there last one. Last edited by smoothdurban; 12-14-2020 at 03:20 PM.. |
#83 |
Redblock for life.
#84 |
Still have my first car
![]() Can I get a TL:DR for what other driveshaft parts are most commonly used in this swap in a 240? I am compiling a wish list.
1. '86 244DL- 1st car & owned for 18 years, 500k miles, 94 B230FT mild build in the works 2. '93 244DL - Daughter's DD, mostly stock with Hydras 3. '07 Vette Z06 - Early mid-life crisis vehicle 4. '17 CRV - Boring DD My feedback thread |
#85 |
![]() A T5 swap in a 240 really only needs a Foxbody Mustang driveshaft + Yoshifab adapter.
https://yoshifab.com/store/240-to-mu...t-adapter.html The 2.3L Ranger damper (F6ZZ4841BA) apparently is the cure for the T5 rattles, but is a tight fit in a 240 tunnel. |
#86 |
![]() Join Date: May 2007
![]() What's the diameter of that thing anyway? at this point it looks like the clearance may not be that different from the V6 one due to the fact that the bulk of that damper is ahead of the u-joint.
#87 |
![]() I'm with you Harald. I'm curious how it'll fit in the 140, might look for one at the yards, test-fit in mine.
Also, the 2.3 Ranger yoke...is that the 1.5" OD or is it the smaller one? The 4-cyl Mustang trans had a smaller output shaft and bushing than the V6 and V8 boxes, didn't know if the Ranger had the small one as well, or if they stepped it up. Also, even with the Yoshi adapter, the Mustang shaft is still a bit short. The Mustang is 45.5" c-c, add 3/4" for the adapter. The correct length is 47" c-c, to get the correct installed depth. Sure, it'll work but it does add a bit more stress to things. |
#88 | |||
I do my own stunts
![]() Quote:
Sorry just saw this Its tight between the firewall and head but it isn't near touching. How much closer would it bring the head if you change your drop angle from 2° to 3°? I would say I wouldn't change that much. Quote:
When I had the v6 slip yoke in I could pull out the DS with out dropping the x member. Last edited by smoothdurban; 12-15-2020 at 09:21 PM.. |
#89 |
![]() Apparently I never measured the diameter of the big damper. But I did find this on my project thread from last year:
#90 |
![]() Looks like I will be busting out the air hammer rather soon.
#91 |
![]() Looks like a 1350 on the yoke, vs 1310 on the driveshaft as well? That part number for the joint is for a bastard joint I'm guessing?
That does give me something to keep an eye out for. |
#92 |
#93 |
![]() Cool, thanks Tyler.
How'd it fit in the 140 tunnel? Granted mine's basically a 240 tunnel, but still, kinda curious. |
#94 | |
I do my own stunts
![]() Quote:
http://forums.turbobricks.com/showth...316868&page=37 Last edited by smoothdurban; 12-17-2020 at 04:48 PM.. |
#95 |
spoolakowski
![]() It almost seems like everyone is using yoshifab driveshaft adapter.... any chance that a dampener could be added in between??
I know someone had mentioned a buick or Lincoln driveshaft (dual cardan universal???) that could really help with vibe issues... but I can't recall where to find that information. t5 counter gear upgrade might be alright: https://www.5speeds.com/t5.htm it seems like tons of t5 owners have this specific problem so I'm not sure it's just b230 t5 to me a slip yolk just seems strange in general. there was also a post that I read online that mentioned a counter weight to create resonance shift. it's not a bad idea i had been thinking about that in regards to the engine but not the trans. my s70 had a pretty large counter weight bolted to it, which i removed but should probably put it back on. A few things to not I don't think we are using that strange t5 trans mount that was hollow and seemed like it'd be less likely to transmit vibration. I had a poly mount in t5... maybe we need a something else there... ![]() can a hydraulic mount of some sort help as a trans mount? i really think that slip yoke is a big issue too much play and load... I was hoping i could find some kind of alternative for the tailshaft in general.
SIG ![]() ![]() ![]() ![]() ![]() ![]() New Project Slug Works my feedback thread here > FEEEEDBACK!!!! |
#96 | ||
I do my own stunts
![]() Quote:
http://forums.turbobricks.com/showpo...&postcount=113 Quote:
I switched my poly mount out for a factory rubber one and I can say it did dampen some vibrations but it wasn't nearly as dramatic as the huge damper or Ben's hybrid torque rods. I like the idea of the counter weight on the rear diff. |
#97 |
![]() Join Date: Jul 2002
![]() I am not sure if I have seen anyone mention this but one thing to keep in mind is that a shorter 2 piece DS setup has a different resonance point then a long single piece DS setup. That itself will change the resonance range, just like the damper posted above.
Also, some 240s came with a dampened driveshaft. I know my 240 turbo came with it. Anyone here try using that?
#98 |
![]() Has anyone mentioned the OEM T5 counterweight that bolts onto the tail housing? I've only ever seen one at a junkyard, and I wish I had grabbed it. It could be interesting to experiment with different weights bolted onto the transmission itself.
#99 |
![]() I have one installed. It helped noticeably.
Sent another one to Mike K. Likely we will have to wait until Spring for his veredict. |
#100 |
