#101 | ||
spoolakowski
![]() Quote:
Ben it seems a number of people have gone with 2 piece driveshafts to help alleviate drive line angle issues. But the vibration still exists. It's been a while but I think when pinion angle is off its a different vibration that the trans itself. Others can chime in I'll be switching to a getrag in the future and will see how I prefer that.
SIG ![]() ![]() ![]() ![]() ![]() ![]() New Project Slug Works my feedback thread here > FEEEEDBACK!!!! |
#102 |
#103 |
![]() Join Date: May 2007
![]() It was about 4 lbs of butyl and iron.
#104 |
![]() Join Date: Oct 2004
![]() Huh, I'll have to see if I have that damper weight kicking around still, the trans I grabbed had it.
I'm also using a factory 2pc driveshaft with the dampened rear half. The trans I'm prepping to go into the car now has that machined retainer as well, so we'll see how that all plays out.
RIP Doug Williams "Mr. Doug" 4/15/2009 Pete Fluitman "fivehundred" 7/14/2013 Mick Starkey "TrickMick" 1/10/14 Mark Baldwin "blue850t5" 7/19/18 Nick Fengler "fengler" 8/6/18 Thomas Fritz "stealthfti" 10/11/18 74 144 B20 http://forums.turbobricks.com/showthread.php?t=224983 90 745Ti http://forums.turbobricks.com/showthread.php?t=334698 If you need Superpro bushings PM me for price and availability! |
#105 |
Redblock for life.
![]() Just finished up swapping in a two piece driveshaft with the Ford F6ZZ4841BA yoke. Also using a 740 support bearing in my 245 as well. Think I might need a rebalance with the new yoke and a bit of angle tweaking but THE NOISE IS GONE! It's like night and day, trans is a Z spec WC T5 with Paul's counter gear stabilizer plate that I rebuilt this summer.
#106 |
![]() Now the question...was it the retainer, the yoke, or both?
I'm doing just the retainer first, then I'll grab the yoke if it's still bad. |
#107 |
Redblock for life.
#108 |
![]() Cool, good info, thanks!
Looks like I'm going yard hunting for a yoke now. |
#109 |
Still have my first car
![]() Is this correct for which models it can be found on?
Ford Mustang 1996-1998 6 Cyl 3.8L 4AT 4R70W, 5MT Ford Ranger 2004-2011 4 Cyl 2.3L NA Petrol 5-Speed Manual Transmission
1. '86 244DL- 1st car & owned for 18 years, 500k miles, 94 B230FT mild build in the works 2. '93 244DL - Daughter's DD, mostly stock with Hydras 3. '07 Vette Z06 - Early mid-life crisis vehicle 4. '17 CRV - Boring DD My feedback thread |
#110 |
![]() Join Date: Jul 2002
![]() Its definitely the Yoke, it has a built in damper, if you have vibrations. You need a damper to change them. The retainer is a good idea for durability reasons but its not going to change the vibration issues that we see using a t5 gear box behind a b230.
#111 |
![]() That's kinda what I was figuring Ben. The only thing throwing a monkey wrench in that is I've been in a 240, with a T5 and B230, that the trans made NO noise, and it's running the standard V8 yoke, non-damped 240 2pc driveline, Trutrac'd 1031, and a flat flywheel. There's also been a couple that had no issues at all, while most of the rest of us, the noise level varies. I brought up the balancer yoke a while back, just have the V6 one on mine now which has the smaller weight on it, and it made a difference.
Either way, eh, I have a spare T5 now, once I swap the one on the bench into the car, with the nice retainer. |
#112 |
![]() Sorry haven’t been keeping up. It’s out in the garage I’ll weigh it tomorrow.
Yeah may go on earlier but won’t drive again until the thaw. |
#113 |
Benchracer Tribe
![]() I see in this thread a lot about T5 vibration in 240s. What about in 700s?
"you can't leave your thingy hanging in public... you can get arrested." "What's Arkansas supposed to be, Kansas for pirates?" Forg "I think I can touch the tire. Damn! I can touch the tire! That hurts!" 240Psycho (on the back seat of my 94 Jetta while I was driving to a J/Y) "Use the barbed adapter like what I use to inflate the air camping mattresses and my dates." FTF Engineering i am inspired. i will replace my windsheild... with an intercooler.swedishK Feedback! |
#114 |
![]() It's a transmission thing, not a car thing.
This is all very good to know, because I have a T5 that got backbenched due to concern about the vibration/noise.
1984 244/ AQ140A / M46 |
#115 |
![]() Its really all about the engine / trans combo. 4 Cylinders resonate differently than a v8 or v6. This is why you get all the rattles and its why Manufacturers installed dampened slip yokes for different engine / trans packages.
#116 |
![]() Anyone know how a T5 trans sound behind a Volvo T5?
#117 |
![]() After all of this discussion I'm still puzzled as the transmissions in Ryan Randall's and Chris Miranda's cars are whisper quiet and perfectly smooth despite using non-dampened slip yokes.
#118 |
#119 |
![]() I'm with you Harald. Multiple engines in Ryan's, years of flat out abuse, poly bushings, you name it, but that thing is silent. My 140, rattles like it's gonna explode, despite fresh bits inside, good fluid, all that jazz.
#120 |
Benchracer Tribe
#121 |
I do my own stunts
![]() I figured I would give this a try simply for fitment.
![]() It fits so perhaps I could try switching back to a different slip yoke to see if it has any effect. With my BFSY installed I didn't notice any difference. ![]() ![]() Perhaps it may help others, PN below. ![]()
1983 242 Turbo w Tremec T5 154,000 km's B230FT LH2.4 2019 VW Golf R w 6 Speed w 2020 kms NEW DD @smoothdurban on IG |
#122 | |
![]() Quote:
You did not notice a difference by adding a damper to the setup with the slip yoke installed? |
#123 |
![]() I actually have one of the NVH weights from an aluminum M46, gonna see about putting that on, see what happens. Gotta get the car running first, so maybe this fall. lol
#124 | |
I do my own stunts
![]() Quote:
I was mainly curious to see if this would fit and perhaps try it out without the BFSL once the weather clears up here. |
#125 |
![]() When I put one of those tailshaft counterweights on earlier this year it narrowed the RPM window the vibes were present in, but wasn't a full solution.
With 2 piece driveshaft and V6 slip yoke FYI
1991 940 - stock b234+t -retired http://forums.turbobricks.com/showthread.php?t=243308 1989 760 - T5 +T5 swapped http://forums.turbobricks.com/showthread.php?t=341191 |
