Old 03-01-2021, 11:10 AM   #26
Added a group on the website for all products for this kit.
Adapters are at anodizing, last bit is to finalize brake line setup
https://www.bneshop.com/collections/...ake-brembo-kit
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 03-01-2021, 11:36 AM   #27
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
I'm assuming these are sized (piston wise) to work with the stock rear?
Old 03-02-2021, 05:49 PM   #28
Yes,
We do have a medium rear upgrade too. Not ready quite yet to release it or details... hopefully soon.
Old 03-02-2021, 06:02 PM   #29
culberro
culberro's Avatar
Originally Posted by blkaplan View Post
Yes,
Ben, Depending on what diameter rotors are being used, there's upwards of ~15-20% brake bias migration towards the front with your design.
Just an FYI.
Old 03-02-2021, 06:18 PM   #30
Just an FYI.
Yes, that is correct.
The rear upgrade should help keep it even, there are also the reduction valves that can be modified to keep the bias even without changing the rear components.
Old 03-02-2021, 09:18 PM   #31
Hank Scorpio
Yes,
Cool!
I've got the full R set for my 245 but I've been kind of thinking I'd rather run 16"s.
Old 03-03-2021, 10:38 AM   #32
Texas240
Prius Owner
Texas240's Avatar
Cool!
I dont have the R's but ive been wanting to find a way to get to a 16" but finding a wide enough tire in a tire that I want is becoming impossible.
93 245 LS Engine Swap Project
Old 03-03-2021, 11:46 AM   #33
Your best bet is a 225 50 16. Thats the most common "wide" tire that's offered.
You can also get 245 45 16 as a wider option, that's OE for some porsche stuff so its still available but you pay porsche prices.
Old 03-03-2021, 11:55 AM   #34
Stiggy Pop
Stiggy Pop's Avatar
Dunlop still has the 200tw Direzza available in 225/45/16 as well, which is what I run on the rear of my car. Excellent tire.
'79 242
943 pickup
Old 03-03-2021, 12:10 PM   #35
Texas240
Prius Owner
Texas240's Avatar
I was hoping to get even larger than that but then you get into tall sidewalls.
Old 03-03-2021, 12:56 PM   #36
245 45 are pretty wide. They are ideal for 8" to 9" wide wheels. Thats not horrible. Are you planning on flaring the car? You cant go much wider without serious modifications.
Old 03-03-2021, 04:05 PM   #37
Texas240
Prius Owner
Texas240's Avatar
Series flaring
Old 04-01-2021, 05:33 PM   #38
Parts just came back from anodizing.
Old 04-02-2021, 10:16 AM   #39
Put them on the 240 under the sirius.
They take a 20mm spacer to clear the spoke profile
[IMG]
[/IMG]
Old 04-05-2021, 02:58 PM   #40
DrZiplok
DrZiplok's Avatar
IMO 240s have too much rear bias to start with, so this is not necessarily a terrible thing...
DrZiplok is offline   Reply With Quote
Old 04-05-2021, 02:59 PM   #41
I have found that to be true as well.
Old 04-05-2021, 03:24 PM   #42
culberro
culberro's Avatar
It sounds like we have different preferences on car setup
I've always found 240s to handle better with more rear bias. Even with no rear proportioning valves a 240 will still lock up the front tires in straight line braking.
Old 04-06-2021, 06:05 AM   #43
petercz
Can we expected similar kit for 7/9? I would really appreciate 320mm 4 pots that can fit under 16" wheels
petercz is offline   Reply With Quote
Old 04-06-2021, 10:38 PM   #44
DrZiplok
DrZiplok's Avatar
That hasn't been my experience, but perhaps you're not getting your tires warm enough before you try braking. 8)
Seriously though, you make a good point; personal preference and specific application needs to be factored in. My experiences tracking a very small number (3) of 240s, all wagons, says they have too much rear brake stock, and big rear brakes just make it worse.
I have no idea what a road-going 240 would want, but it's probably not what I want. 8)
Old 04-07-2021, 01:38 AM   #45
culberro
culberro's Avatar
What’s the weight on the wagons and weight distribution?
My stripped out and caged mk2 GTI had less rear weight distribution than stock, so it ran cheap cheap pads out back and bigger brakes up front. But that car was like 67% front.
Old 04-07-2021, 12:47 PM   #46
Pad compounds are also a good way to balance a system. The pads I'm running now with the 286mm rotors and brembos have significantly less u then factory volvo pads but they also don't dust at all and are silent, which I'm ok with for the moment.
Old 04-08-2021, 04:05 PM   #47
Posted brake line kits.
