Old 03-08-2021, 01:08 PM   #1
suener
Default ugh so many issues
1992 240 wagon m47 5 speed 3.1 lh no egr nonturbo
First good morning,
Ok where to start? I am only going to post 1 issue at a time although they may be all related or unrelated. so hard to tell.
My car is getting up there and I have been neglectful in the past, but now I feel bad and am trying to do right by her.
The biggest issue right now is no/delayed responsive via accelerator or throttle manipulation at normal operating temp. This is relatively new symptom
There are no issues with response while cold.*
There zero starting issues
*rpms SEEM high - no tach but I did order one and will test asap.
I have checked and replaced the IAC, cleaned the throttle body, replaced the air intake boot between MAF and throttle, checked throttle cable and pulley, Checked ignition codes (ok), check ODB codes - rich/lean at cruise and idle, fault at fuel injectors (ordered) Checked MFA with multi-meter (read 110 omhs) and car immediately died when I unplugged the MAF, checked fuel pressure regulator (no leaks), checked hoses for air leaks but as of yet found none. Tested the TPS at cold (test results ok) but I did not test at operating temp (sadly I just thought of that now)
HOWEVER none of that is the question I want to post today it is just for background.
I know that because this is a system and all components must work together I am merely trying to narrow the issues down through elimination.
So what I want to identify is this:
Currently the idle seems high and is definitely erratic. the longer it runs the lower and more erratic idle becomes- but she doesn't stall out unless I press the gas. It feels as though the car is bumping- that is how erratic it can be-almost as if she fits and starts like sporadic gurgles (idk how else to describe it) in addition to the erratic idle
Any suggestions about would be greatly appreciated and I thank you for your time
suener is offline   Reply With Quote
Old 03-08-2021, 02:05 PM   #2
Start with a full tune up. New plugs, wires, cap and rotor. The bumping you are describing seems like the engine missing. Worn out plug with too wide a gap can do weird things. I'd also replace the fuel filter if it hasn't been done in a long time.
Is the speedometer working? No speedometer means a high idle after you get done driving on the highway as the computer wants to see a vehicle speed signal. If it doesn't see that signal you get a high idle after driving.
Old 03-10-2021, 03:02 PM   #3
2manyturbos
The issues you describe point to a bad air mass meter. The surging idle, no throttle response and sudden stall when the throttle is applied are all classic symptoms of a bad AMM.
Old 04-03-2021, 08:42 AM   #4
dalek
Benchracer Tribe
dalek's Avatar
I myself have that issue.
If that is the case, can't he do the "disconnect AMM plug and see how it behaves" test?
Feedback!
Old 04-03-2021, 03:40 PM   #5
He did. The engine stalled which may not be the AMM fault. Check out the cleanflametrap web site for help with diagnosing a bad AMM. I do agree that the running symptoms are typical of a bad AMM. A clogged fuel filter can also cause this running issue.
