Old 03-10-2021, 08:32 PM   #1
90volvo
Default throttle body size?
My setup
-ported 530 head with bigger valves
-Rsi stage 3 cam
-header
-GTX3076r turbo
-1000cc inj.
-KLracing intake
-treadstone intercooler
-E85
The bolt pattern of the klracing intake is 77mmx77mm, is there a throttle body available to fit this bolt pattern or close like 75mm? The on klracing website they recommend an 80mm throttle body, which is huge but this intake is huge. Like to know if anybody think a 65 or 70mm would work fine or would it mess up the balance. Thanks for any help, appreciate it.
B230ft rebuilt -MS-Turbo-E85
1985 240 Work in progress.
Old 03-10-2021, 08:59 PM   #2
2turbotoys
Salaminizer
2turbotoys's Avatar
They sell a matching throttle body. I only see it if you go to the intake manifold page and scroll down to accessories. At $141, its not a bad deal. If you can get it here for a reasonable cost. Still, even if its a bit over $200 when it gets to you, that's not bad at all. And it looks cool haha.
https://shop.klracing.se/sv/artiklar...llet-80mm.html
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 03-10-2021, 09:05 PM   #3
culberro
culberro's Avatar
Large TBs are kind of a waste. There are plenty of boosted 800-1000 hp cars using 65-70mm throttle bodies.
The subaru sti DBW throttle body is pretty common in the aftermarket world, and it's 65mm iirc.
With boost the air density is much greater, so you can flow a larger mass of air through a smaller TB.
With the TB before a supercharger, and NA engines, atmospheric pressure is the only thing pushing air in.
Old 03-10-2021, 09:16 PM   #4
2turbotoys
Salaminizer
2turbotoys's Avatar
But he wants one that bolts to the intake. They also make 70 mm throttle bodies.
Old 03-10-2021, 09:29 PM   #5
culberro
culberro's Avatar
Take a plate of aluminum and make an adapter with a hole saw and a some drill bits?
I mention this because this is exactly what I'm doing for a local person with a KL racing sheetmetal manifold.
Or buy 960 TB plate from YoshiFab and attach that?
Old 03-10-2021, 11:02 PM   #6
90volvo
What size did he go with? But yeh, I can build an adapter but that takes time and money for drill bits etc. The carbide hole saw probably cost the most. I figure 3x3inch pattern would be pretty popular. Anyways thanks for the info.
Old 03-11-2021, 01:49 PM   #7
culberro
culberro's Avatar
No need for a carbide hole saw, a simple Lenox steel one is fine for cutting aluminum.
The TB I'm adapting is something like this a generic 65mm billet one from ebay. I think it was ~$70 shipped.
Old 03-11-2021, 03:09 PM   #8
shoestring
shoestring's Avatar
Big fan of Lenox products.
Old 03-13-2021, 12:39 PM   #9
h20ham
Which AMM MAF are you using
How did you get here
h20ham is offline   Reply With Quote
Old 03-14-2021, 02:00 PM   #10
90volvo
Running megasquirt. 3 inch ic piping
Old 03-25-2021, 03:53 PM   #11
Jussi Alanko
If you have 3" ic piping you want to put a kl-racing's 70mm throttle body to it. It will fit straight away and it's exactly same size than your ic piping.
Jussi Alanko is offline   Reply With Quote
Old 03-25-2021, 07:28 PM   #12
90volvo
thanks
Old 03-27-2021, 06:17 PM   #13
Chilm
Double Dutch
Chilm's Avatar
Can be of any help:
Click
Flying Dutchman - Build and goodies thread ;P
Volvo 945 - Blue Pearl - LPT Polar 2.3 Limited Edition
B230-FK Turbo - 90+ ported - 15G Ported - Airintake
Erland Cox Regrind - Blabla Chips - 3 inch exhaust
MBC on 0.95 - Wasted Spark - Sponsored by my wife
Chilm is offline   Reply With Quote
Old 03-28-2021, 08:12 AM   #14
DET17
Reformed SAABaholic
As was stated earlier, the giant TB's are of little benefit in a turbo application. I've got an analysis saved somewhere that validates the stock redblock TB will support almost 400hp.... pretty sure that is the 65mm size.
Add to that, there are driveability issues with throttle tip in....... ask Gsellstr as he tried to run one and found it unbearable in transition driving. The exception that might make the 960 size TB tolerable, is the style which has the plastic restrictor wedge on the actual blade; this certainly is the reason the OE Engineers installed this device..... and the TB Geniuses immediately remove it for MO POWR .........
Old 03-28-2021, 09:10 AM   #15
90volvo
Im running 65mm with ms2 and the lowend is good. Will say when I was running 3 inch IC piping it killed the off idle torque. I switched to 2.5 and the lowend came back. The IC had 2.5 inlet and outlet. Anyways, just thought Id share my experience. Thanks for advice.
