Old 03-11-2021, 03:56 PM   #1
DavePolyakov
Default Rebuilt head 10k miles ago, valve adjustment?
Sorry for another valve adjustment post. PO rebuilt the head 10k ago on my 1990 b230ft. I'm installing the IPD turbo cam. I shouldn't need to adjust the valves right? I don't have a feeler gauge or a shim kit. It's probably good to go though correct?
DavePolyakov is offline   Reply With Quote
Old 03-11-2021, 05:09 PM   #2
shoestring
shoestring's Avatar
You should check and adjust as necessary.
Old 03-11-2021, 05:22 PM   #3
culberro
culberro's Avatar
PO rebuilt the head or a shop did?
Some shops run really thin valve seat widths that will "pound in" (quote from an actual machine shop). This makes the valves seal up well initially, but can cause valve seat and valve face wear issues, which can require lash adjustments until everything finds a happy medium. Not my preferred method, but it's commonly done.
Old 03-11-2021, 05:37 PM   #4
DavePolyakov
It was a shop. I can invest in a feeler gauge and check after the install of the new cam, but if I need to acquire valve shims should I go to a Volvo dealership? IPD doesn't have a rent kit anymore?
Old 03-11-2021, 06:26 PM   #5
gsellstr
gsellstr's Avatar
If you're changing the cam, regardless of brand of cam, cam choice, head condition, etc, it's smart to at the very least check the clearances to make sure nothing is being held open.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 03-11-2021, 08:35 PM   #6
The last IPD turbo cam I installed. I had to change all eight shims to get the proper clearances. By the bent type of feeler gauges. They fit easier and make it easier to check the clearance.
Old 03-11-2021, 08:56 PM   #7
culberro
culberro's Avatar
Don't forget to remove the hushers and toss them in the trash.
Old 03-11-2021, 09:00 PM   #8
culberro
culberro's Avatar
Is there a volvo, fiat or alpha (?) mechanic in your area? Most independent mechanics will sell you the shims you need.
I use a 3.5mm shim to check lash on new builds, and then order the needed shims.
Old 03-12-2021, 12:03 PM   #9
rb92673
Do yourself a favor and get some Go-No-Go feeler gauges. Makes it so much easier.
Lisle 68150 Go-No-Go Feeler Gauge - $12 on amazon.
Old 03-12-2021, 12:20 PM   #10
DavePolyakov
On the same listing, you can select "Valve feeler gauge" in which they are at an angle. Lisle 68050. These will be easier to use right? And they're half the price.
Old 03-12-2021, 12:23 PM   #11
DavePolyakov
Yes, I believe there are I just haven't contacted them before. Does anyone in the Seattle area have any specific shops to recommend?
Old 03-12-2021, 02:13 PM   #12
rb92673
Those will work too. The Go-No-Go versions have a step in the feeler that is two sizes up. It makes it easier to figure out what the clearance is to me. I take the feelers out of the holder, so the angle doesn't make a difference to me.
I also needed a micrometer to measure the shims.
I had to go to ebay to find some of the shims I needed in December. IPD was out of stock.
Old 03-12-2021, 02:42 PM   #13
The Librarian
How much are you paying for shims from ebay? Some of the prices I'm seeing are ridiculous.
https://www.ebay.com/sch/i.html?_fro...+shim&_sacat=0
I keep a full complement of shims in stock and I'd even rent out the kit with tools but the deposit I'd need is steep. I charge $5/shim so just the cost of the shims in the kit is $850.
Old 03-12-2021, 03:02 PM   #14
gsellstr
gsellstr's Avatar
I bought a lot of stock on shims when FCP had them on clearance a while back. About 3/4 of my kit is good used, the rest is new, but yeah, it sure as hell ain't a cheap think to build.
Old 03-12-2021, 03:35 PM   #15
rb92673
I couldn't find a 3.65mm anywhere and I think I spent $15 shipped for it on ebay. I should have just called you. The rest I got from IPD for about $4 each.
Old 03-12-2021, 07:06 PM   #16
DavePolyakov
So I guess the most sensible course of action is to remove the old cam, install a new cam, measure valves with feeler gauge, then buy individual shims from IPD and/or eBay availability permitting. If I don't mind the noise should I really just remove the hushers? If they're in good shape why not leave them in?
Old 03-12-2021, 07:21 PM   #17
philski o'flood
philski o'flood's Avatar
measure the new cam without the old hushers,
measure the shims and see if or how many you can swap around
it's really best to have the kit or a bunch of different sized shims on hand when
doing this, as the chances measuring once and ordering the right shims is slim
if you want to use new hushers install them after all the clearances are correct
philski o'flood is offline   Reply With Quote
Old 03-12-2021, 10:03 PM   #18
culberro
culberro's Avatar
You can definitely use hushers, you just have to remove them to check the lash. If you check lash with new hushers installed, you're going to have a confusing day.
Old 03-12-2021, 11:03 PM   #19
Mr. V
Mr. V's Avatar
I avoid having to use the tool by measuring all the clearances and then removing the camshaft; then I replace shims as needed and reinstall the camshaft.
Old 03-12-2021, 11:21 PM   #20
bobxyz
bobxyz's Avatar
What's reasonable guidance for a machine shop "tipping the valves" versus changing shims? Is up to ~8 thou (2 shim sizes) OK?
Old 03-13-2021, 12:45 AM   #21
philski o'flood
Dave you can do it
Old 03-13-2021, 01:57 PM   #22
Ferrari 308 also uses the same shim as our Volvos. Of course if you say the word Ferrari then the price of the shim doubles or triples.
Old 03-13-2021, 02:38 PM   #23
2manyturbos
IPD sells the shims for $3.69 each. Just measure the clearances and the shims that are currently in place. If any are out of spec, order the correct shim to get the clearance within spec. It doesn't have to be exactly the same on all 8. IOW, don't overthink it. Just get the clearance to fall within the acceptable range for each valve.
Old 03-13-2021, 03:28 PM   #24
DavePolyakov
Thanks for sharing your example. I added some labels to it, can someone tell me if I did it correctly? I know the units may be redundant but I'm just being cautious. Feeling a lot better about this now. Seems pretty straightforward.
Originally Posted by philski o'flood View Post
Dave you can do it
Old 03-13-2021, 03:31 PM   #25
The Librarian
IPD isn't stocking all the sizes Volvo used to sell and they're out of stock on a few of sizes they do sell. Of the 25 sizes available from Volvo IPD only has 21 listed on their site and currently 6 of those are out of stock.
The kit I assembled has 34 sizes, 3.25mm-4.9mm. One smaller and 8 larger than the standard kit. I can also special order shims from 2.55mm to 5.2mm thick.
