![]() So I've done a number of performance mods to my 940 turbo over the years and now I think I want to put in a better performing cam as I still have the stock one. I want one that would work best with the mods I've done to the car as well as will work well in the future if I decide on going with an even bigger turbo than I currently have. My mods are as follows:
Angled flange 16t currently at 15psi (I haven't gone to 20psi yet) 3 inch angled flange downpipe with no exhaust currently Bigger 012 maf with a 3inch intake pipe I made and an AEM dry flow filter Volvo blue 395cc injectors TLAO ignition and fuel chips Aftermarket transmission cooler AW71 accumulator mod So that the basic list of what I've done so far. I want a cam that's going to give me more power but I'd also like a more aggressive lopey idle. I've been looking at the obvious IPD turbo cam but have also run across old posts saying the Kg2T cam is very good too so I'm looking for opinions on both as well as any other cams that may even be better. I was also curious on three things: First: do I need to worry about shimming after I install a different cam? I've read a lot of posts but people rarely talk about it and it doesn't seem like it's really needed from what I've read so far Second: Do I need to get an adjustable cam gear? I've read about people advancing or retarding timing with them but I've seen a lot more posts saying they don't really use them. Third: Does installing a performance cam make the engine interference? I've read conflicting things on that. So yeah that's basically it, I'm hoping I can get some helpful insight so I can make up my mind. Thanks everyone. |
![]() 1st) Yes.
2nd) No. 3rd) Probably. Experience at this house likes the Enem V15T.
![]() i love my V16t fun to drive has a bit of a lumpy idle too
1987 244 B230f+t @17psi 19t V16t cam Lite Ported 531 Head Stock Skinny rod Block Do88 intercooler Stock AW71 Praying for a window free block |
#4 |
![]() First, Yes.
Second, No but it is good to use the adjustable gear to help enhance lower rpm torque. Helps with an automatic. Third. A small price to pay for more performance. I also use and recommend the V15T. For more performance the V16T is great. Some head flow work will help you take even more advantage of the mods you have done.
Dave, 1982 242 turbo. 338k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration. 1993 245 Classic, 430k miles, enem V15. IPD bars and chassis braces. Simons sport exhaust from Scandix. sbabbs ezk chip. Been a good road warrior. Genuine Volvo rebuilt leaky M47. ![]() |
#5 |
![]() So I've been hearing about the v15 and v16t cams but from what I've searched for there doesn't seem to be anywhere to buy them?
I've also recently come across the KL racing cams, the T2 and T3, they seem pretty decent from what I can find and they aren't that expensive but from the small amount of info the website offers apparently I need to buy 2.5mm or 3mm lash caps and install them with the cam? That's the first I've heard of doing that in a b230. I'm assuming the lash caps are easy to install and just go in the place where the husher would normally be? |
#6 | ||
$599 Volvos
![]() The ipd turbo cam is the same as the V15. Or buy those other cams right from enem.se
#7 |
![]() The only slight difference in the IPD turbo cam and the enem V15T is the lobe angle. IPD used to say the lobe angle on their cam is 110 degrees. While the enem cam is 112 degrees. Both will work fine but the lobe angle is more suited to a turbo engine at 112.
#8 |
![]() I have a KL racing T2 in my b230ft, it has a nice powerband with a t3/t4 and an m46 with 4.10s, but I think it'll be underwhelming with an automatic until you get the revs up, at which point the 16t might start holding you back as well
#9 |
![]() So I ended up going with a kl racing T2 cam. I also bought a drop in kl racing intercooler for my 940 because apparently it's a huge upgrade from the factory intercooler. I'm excited to see how this will affect my performance when I've got it all in.
#10 | |
![]() Quote:
Ps. did you remember to order 2.5mm lashcaps, it will need those. If not, i think that many speedshops have those lashcaps at 8mm shaft size and 2.5mm long. |
#11 |
![]() Yes I purchased 8 of those 2.5mm lash caps along with everything else. I'm currently trying to figure out where I can get or rent a shim kit from to have on hand when I have to measure and reshim to set the correct valve lash. Also gotta buy a new feeler gauge and a decent micrometer.
#12 |
Who engineered this?
![]() Enem V16. Don't be a pussy.
#13 |
The MP
![]() Where are you? I have saved all the shims i encountered over the years, and keep them in a tray with compartments. Maybe someone near you has done the same.
#14 |
#15 |
#16 | |
Reformed SAABaholic
![]() Quote:
Unless FCP Euro no longer has stock..... ![]()
Project "cheap thrills" build thread: http://forums.turbobricks.com/showth...67#post4211467 Feedback thread: http://forums.turbobricks.com/showthread.php?t=198746 Last edited by DET17; 03-30-2021 at 05:13 PM.. |
#17 |
The Librarian
![]() I assembled an extended shim kit (34 sizes vs. 25 and 5 of each size vs. 4) with tools, lash caps, hushers and solid dowel pins with the intention of renting it out but the deposit required makes it prohibitive. I sell individual shims for $5 each.
#18 |
#19 |
cone dodging dilettante
![]() Someone should send one of those KL Racing cams our way for measurement.
1993 944 B230FT/M90 thread here: http://forums.turbobricks.com/showthread.php?t=345277 2x 1991 245 B230F/M47 (LeMons car, street car) I sell chips for LH 2.4! |
#20 |
Double Dutch
![]() Good old V cam is a very nice cam imho.
P.s. shims as in lash caps goes under the bucket. I've got a Folkrace regrind open turbo cam for sale: Lobe angle 114 Duration: 265 Lift: 11,6 With lashcaps. So make me an offer =P
Flying Dutchman - Build and goodies thread ;P ======================================= Volvo 945 - Blue Pearl - LPT Polar 2.3 Limited Edition B230-FK Turbo - 90+ ported - 15G Ported - Airintake Erland Cox Regrind - Blabla Chips - 3 inch exhaust MBC on 0.95 - Wasted Spark - Sponsored by my wife ======================================= Last edited by Chilm; 03-27-2021 at 06:07 PM.. |
#21 |
![]() This is what the IPD Turbo cam did in my NA B230F:
- Cylinder head bowls cleaned up - 3 angle job on valves - valves deshrouded - MS3 conversion - IPD Turbo cam retarded 2 degrees - stock everything else including catalytic converter Red = hp / blue = torque, top line is on Petrol, bottom line is on LPG. Ignore the peaks at max RPM, they are caused by the rolling resistance calculation since this is crank power. ![]()
[1991 Volvo 240 sedan, daily driver ![]() ~Gotta love that GL trim~ The excessive TD04 turbo guide ®™ |
#22 | |
Double Dutch
![]() Quote:
??? Last edited by Chilm; 03-28-2021 at 07:57 AM.. |
#23 |
#24 |
![]() How much were you renting it out for? I want to have a kit on hand when I do this so I have minimal downtime. The parts just arrived from Sweden the other day so I'm in the planning stages at this point of when will be a good time to do it with my schedule.
#25 |
The Librarian
![]() PM'd
