Old 03-26-2021, 10:31 PM   #1
84B23F
84B23F's Avatar
Default AW71: Oil Pan...Drain plug stripped
So, drain plug is stripped...any option to fix it...or just close access to it?
thx
Old 03-26-2021, 11:24 PM   #2
c1800
Will it hold in place? If you just changed the oil, put it back in with some RTV, you’re probably good for a “while”.
Old 03-26-2021, 11:27 PM   #3
IansPlatinum
IansPlatinum's Avatar
Pretty sure it's a steel bung tacked in place to the pan. And the threads didn't look like they had any "meat" on them to bore and rethread. I think a new pan is the way to go imo
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
'93 Land Cruiser - "Ruby"
'01 Cherokee - "Janice"
Old 03-27-2021, 12:40 AM   #4
planetman
planetman's Avatar
Maybe if I wasn't a "new timer", I might be able to offer help.
thx
Eric
Torrance, CA 90502
Old 03-27-2021, 12:58 AM   #5
c1800
old timers welcome too.
Old 03-27-2021, 09:16 AM   #6
84B23F
84B23F's Avatar
Volvo 1233415 - No longer available worldwide...in my searches
Volvo 1208642 (Automatic Transmission Assembly) - New transmission is available, for $4,097.30 (plus tax and S&H).
Volvo 1233071 0-Rings (2) were replaced on cooler lines' elbow-fitting, and then oil-drain bolt stripped when tightening...Bummer.
I'll take a look at it when I remove oil pan; it might be best to plug it permanently.
Old 03-27-2021, 11:41 AM   #7
https://forums.turbobricks.com/newth...newthread&f=14
Old 03-27-2021, 01:12 PM   #8
tintintin
car-part.com for a used pan?
Old 03-27-2021, 01:39 PM   #9
283SD
Re tap it to the next bigger size if the plate in the pan is intact.
Old 03-27-2021, 05:55 PM   #10
sbabbs
sbabbs's Avatar
Be wary of used pan that oil dipstick tube threads is the part that is usually also bad from overtightning also. In other words make sure that is good also....
Old 03-27-2021, 08:41 PM   #11
84B23F
84B23F's Avatar
Correct Answer - 3/8" x 16 tap
This would be the ideal replacement bolt: 3/8"-16 STAINLESS STEEL BUTTON FLANGE HEAD SOCKET CAP SCREW (3/8"-16 x 3/4"), but a cut-off saw will be needed to shorten it.
They pressed in a bushing that was tapped....Here's what it looks like now, with a serrated bolt having a screw head.
thx all...
Edit: I found some on Amazon
Old 03-31-2021, 01:17 PM   #12
lummert
lummert's Avatar
Drain plug with self tapping oversized threads comes to mind.
Old 03-31-2021, 06:59 PM   #13
84B23F
84B23F's Avatar
That will work, but using a 3/8-16 tap seems to do the trick; With a pinch of silicone on flat surface, I'm going to try this: 3/8-16 x 1/2 Inch Button Head Socket Cap Screws Bolts, Stainless Steel
Old 04-01-2021, 09:48 AM   #14
283SD
Grease the tap flutes to catch the metal shards.
Old 04-02-2021, 08:45 PM   #15
84B23F
84B23F's Avatar
Problem was the drain plug was spinning in its position; I had to remove the pan, apply pressure on top of bolt's threads, then turn to remove it.
Footnote - I had to replace these O-rings, due to a transmission oil leak
When it got real cold around here, transmission's cooler line was leaking where it inserted into transmission. 28 year old o-ring failed...I suspect it didn't expand after that cold weather...minus 20 F or so.
