Old 03-27-2021, 08:29 PM   #1
dkrause
Default Modifying B230 head for big valves
I am installing "group buy" big valves in a B230-530 head, My engine machinist wants to know if he can safely cut the head back to the "Bore scribe line" to open up the flow? Is there any danger in cutting through the head when he machines this on Exhaust or Intake?
dkrause is offline   Reply With Quote
Old 03-28-2021, 02:04 AM   #2
culberro
culberro's Avatar
No problem whatsoever.
Make sure the seat throat ID is 86-88% of the valve OD, and don’t sink the valves into the head.
Also, make sure they use bronze guides or guide liners. SS and inconel valves do not like cast iron guides.
Old 03-29-2021, 01:15 AM   #3
dkrause
Thumbs up
Thanks just what i wanted to hear, new bronze guides all around, and new oversized seats, I will make sure they don't recess them!
Old 03-29-2021, 12:37 PM   #4
culberro
culberro's Avatar
No real need for OS seats, as the stock seats work just fine with 2mm+ OS valves.
If they do replace the seats, make sure they are heavy duty seats or you'll be adjusting the valves more frequently. The OEM Volvo seats are REALLY GOOD, and most replacement seats are not nearly the same quality.
