Old 03-28-2021, 12:28 AM   #1
makebrickgovroom
makebrickgovroom's Avatar
Default Alternatives to BTI bracket?
More of a niche question, but i was curious if anyone knew of a similar wasted spark 4 tour unit similar to the BTI kit:
https://www.classicswede.co.uk/Waste..._18276167.aspx
worst case, shouldn't be too terrible to make one of these, right? I'm bad a fab work but would be willing to screw around to make something work. Thanks in advance!
"dolly parton"
'84 245 d24 --> b21ft + ms
makebrickgovroom is offline   Reply With Quote
Old 03-31-2021, 03:28 PM   #2
supreme940
supreme940's Avatar
You could try getting a coil bracket from the junkyard from something that uses EDIS 4, chop it up with a angle grinder and then weld 4 sheet metal legs on to mount to the valve cover.
supreme940 is offline   Reply With Quote
