Old 03-29-2021, 11:18 AM   #1
sloopy
na
sloopy's Avatar
Default 240 lithium battery
I picked up a braille g30 lithium battery from summit. 5.5 lbs!!!
https://www.summitracing.com/parts/brl-g30
For now, I just removed the battery tray and used cam buckle straps to hold the battery down. I'll be making a proper sheet metal tray lined with foam which bolts in place of the original battery tray. Nothing terribly wrong with how it is right now except that I'm using some folded up paper towels to protect the straps from the metal edges. The cam buckle straps are manufactured by fasty of sweden :o)
https://i.imgur.com/J2twB4C.jpg
1992 volvo 240 wagon:
> flavor: black on tan
> suspension: stock + 23/19mm f/r arb
> wheels: 14x6" enkei 92 + 215/70R14
> drivetrain: M47II + 3.31 + open diff
> engine: B230F + 2.5" exhaust
sloopy is offline   Reply With Quote
Old 03-29-2021, 11:32 AM   #2
JohnMc
JohnMc's Avatar
Teeny tiny! I've been using a more conventional 11.5 AGM Braille battery in my 245 for a while. Probably not ideal for extended cranking if you have starting issues, but I've had no issue. Probably also helps that I don't drive it in the winter (because they salt the roads here). Works entirely normally, with the 16V redblock before and the 16V whiteblock (alu LS heh) motor it has now.
EDIT: The 11.5 lb one I've been using: https://www.summitracing.com/parts/brl-b14115
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 03-29-2021, 11:49 AM   #3
$599 Volvos
Did you save up for this or did you buy it with Biden bucks, or are you independently wealthy?
Chturd - pullyourbootstrapsupandsuckituplooser
Chturd- keepyerfilthyhandsoffMYMONEY
Old 03-29-2021, 12:01 PM   #4
sloopy
na
sloopy's Avatar
I blew all my money on it
Old 03-29-2021, 12:28 PM   #5
James M
Bored member
James M's Avatar
The normal TB method is to blow your money on a +t and an HF angle grinder, what kind of world do we live in with $500 batteries in $600 volvos (sorry $599)
Old 03-29-2021, 12:31 PM   #6
cwdodson88
The Build Thread
SVEA - PUSHROD TURBO!
Old 03-29-2021, 01:11 PM   #7
JohnMc
JohnMc's Avatar
$500 Volvo + $500 battery = $400 Volvo.
Wait...
Old 03-29-2021, 06:24 PM   #8
You always should spend more on the upgrades than the car you started out with. It's part of the fun!
Old 03-29-2021, 06:35 PM   #9
JohnMc
JohnMc's Avatar
I've certainly done that on 3 of my 5 cars. And it's only a matter of time for 1 of the other 2. Maybe both.
Old 03-29-2021, 06:42 PM   #10
esmth
I see it is 1/3 of the weight, but any other reason you decided to splurge for lithium instead of, say a pc680?
I have had pc680 in my dd all winter with zero issues
1991 244 LH2.4 M46 352k miles
esmth is online now   Reply With Quote
Old 03-29-2021, 07:15 PM   #11
sloopy
na
sloopy's Avatar
Expected service life is 10 years.
You can actually use over 90% of the capacity, still output 13.3V, and it won't damage the battery.
So even though the battery is rated as 15AH, the usable charge capacity is comparable to a 45AH lead acid battery. So only a small downgrade compared to the standard 60 or 70AH lead acids.
Also, output is about 13.8V at full charge. So stronger starting and the windows roll up faster with the engine off (very important)
Old 03-30-2021, 01:44 PM   #12
mikep
The MP
mikep's Avatar
5x price for 2x life?
Originally Posted by Lord Tentacle View Post
Yes please!
Want a kangaroo hide?
Originally Posted by Shifted View Post
Now why would I want to hide my kangaroo.
Old 03-30-2021, 02:02 PM   #13
culberro
culberro's Avatar
First thing this is TB, you overpaid by going with a Braile battery. They are re-badged Deka batteries most of the time. Braille has a tendency to "up-rate" them by using a different testing procedure.
Dakota Lithium has a LiFePo battery with similar specs for about half the price.
There are a lot of YTX20 and YTX30 lithium batteries out there, they range in price from ~$200-300. Cheaper if you don't want any sort of warranty. As long as you don't puncture a cell or be an idiot with it, the cheap ones should be fine.
To all you LiPo haters, you can get a LiFePo battery now and they are extremely safe
Old 03-30-2021, 02:07 PM   #14
sloopy
na
sloopy's Avatar
3x the capacity at 1/3 the weight
Old 03-30-2021, 02:10 PM   #15
sloopy
na
sloopy's Avatar
As far as I know, only braille's agm batteries are re-badged. Their lithium batteries are made in house in florida. I'd be curious to know who they're getting their lithium cells from.
Good to know about the much cheaper option though.
Old 03-30-2021, 02:11 PM   #16
JohnMc
JohnMc's Avatar
45 AH is triple the capacity of what?
Old 03-30-2021, 02:15 PM   #17
sloopy
na
sloopy's Avatar
The tiny lead-acid pc680 esmth was talking about
Old 03-30-2021, 02:17 PM   #18
JohnMc
JohnMc's Avatar
Well sheeeeeit. *googles*
Looks like the next time I need a Braille B14115 I'll be getting a Deka EXT14 instead. Same damn thing, ~$85 vs. $150.
*sigh*
Old 03-30-2021, 02:41 PM   #19
culberro
culberro's Avatar
I'm 99% certain they're just badge engineering LiPo batteries from China through a contract manufacture that everyone else uses. There are very few actual battery manufactures and assemblers in the US. Even less so with "small" batteries.
The Braille Micro-Lite carbon fiber cased Li batteries are "built by a Braille Factory Technician in the USA", using "hand selected" cells.
Upside: You paid extra for a real warranty from a real company!
Old 04-03-2021, 01:12 PM   #20
dalek
Benchracer Tribe
dalek's Avatar
Using Corinthian leather?
Feedback!
