Old 03-29-2021, 08:47 PM   #1
Rat Dangerous
Default Momo hub adapter steering wheel column problems
I have a 1994 940 wagon and recently installed a momo hub and adapter. ever since installation my steering column makes a scraping sound when turning. The bolt was torqued to proper spec and its bugging me. It sounds like its coming from near the hub.
Rat Dangerous is offline   Reply With Quote
Old 03-29-2021, 10:06 PM   #2
TIPSP
Got Boost?
TIPSP's Avatar
Its probably just rubbing the plastic cover. pretty typical. Mine did that also. but I haven't noticed it in a few years. check where its rubbin.
Old 03-30-2021, 10:16 AM   #3
It could be the groudning pin that makes contact with the horn ring. A little bit of grease on that surface could help if that's the case.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 03-30-2021, 10:17 PM   #4
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
Hope you figure it out.
Is this the 9011 hub adaptor? I need to get one for the 91 745 - just checking that that is the correct adaptor
Old 03-30-2021, 11:26 PM   #5
Rat Dangerous
Yea it is fits like a charm. You can also just measure your steering rack spline diameter very easy to do.
Old 03-30-2021, 11:27 PM   #6
Rat Dangerous
Good idea this sounds like it exactly! Thanks.
Old 03-31-2021, 09:33 AM   #7
We have em in stock mate.
https://www.bneshop.com/collections/...-wheel-adapter
Best to measure, then to guess.
Old Yesterday, 06:11 AM   #8
VolvoGuy123
VolvoGuy123's Avatar
Hey, did you ever solve your problem? I just started my new momo wheel install using the momo (9011) adapter and it doesn't seem to fit correctly. The spline is correct but that black plastic ring that accepts the stock wheels spring loaded horn pin does not line up with the 9011. I can cut the black plastic sticking out and that might work but I'm reluctant to make any irreversible changes yet.
VolvoGuy123 is offline   Reply With Quote
Old Yesterday, 06:14 AM   #9
VolvoGuy123
This is my setup. 1995 940 turbo.
Old Yesterday, 05:52 PM   #10
im pretty sure that black ring gets removed.
Old Yesterday, 06:20 PM   #11
VolvoGuy123
Ah, I was thinking of that or just trimming it to fit because the orange SRS wire is also still in the way. Do you happen to have any idea how to properly remove it before I just rip it out gorilla style? lol. Thanks.
Old Yesterday, 09:25 PM   #12
Rat Dangerous
There is still rubbing that I never fixed yet, but also mine did not have the black ring so it has been installed since. The rubbing is no problem as of now very minor
Old Yesterday, 11:02 PM   #13
VolvoGuy123
That's weird, we basically have the same car 1 year apart. Volvo and their weird manufacturing practices! lol. My year didn't even have a turbo badge or gauge. But Did you try spraying dry silicone or something all up in the mechanism? Maybe some dielectric grease. I'm going to try to cut out the black plastic spin ring.
Old Yesterday, 11:03 PM   #14
VolvoGuy123
Thinking about it, my air bag wire (orange) is connected to that black ring. How is it on previous (or alternate) years? Unless it's separate and just looks that way?
