Old 03-30-2021, 12:03 PM   #1
mikep
The MP
mikep's Avatar
Default 240 Fuel Tank Thickness
Ken made a comment somewhere about fuel pump whine with an aftermarket tank.
I needed one, and rock auto listed 3.
Liland Global $132, listed wrong height (all 3 used differing nomenclature)
Spectra $172, aplication for a 1992 “carburetor”. Listed on autozone as 25lbs (with box?)
Dorman VL1B, out of stock, $? Listed on autozone as 18.25lb.
That left me with one “real” option:
Use a volvo tank. Save your old one if it can be cleaned. I am about to return this Liland Global.
16.5lbs .035” steel with a 60mm deep sump vs 22lb .052” steel with a 115mm deep sump for the volvo.
Guaranteed to be noisy, lose pressure in hard turns under 3/4 tank, and leak in a wreck.
Maybe i’ll try a different one. I doubt they’ll go look at the sump or weigh it for me.
Originally Posted by Lord Tentacle View Post
Yes please!
Want a kangaroo hide?
Originally Posted by Shifted View Post
Now why would I want to hide my kangaroo.
Old 03-30-2021, 12:19 PM   #2
esmth
I have a spectra tank with a single dw200 pump inside. I can't compare the noise to the factory parts, but it was quieter than the stock inline pump and IPD "upgrade" in tank pump what I had before the original tank rusted through.
1991 244 LH2.4 M46 352k miles
Old 03-30-2021, 04:31 PM   #3
culberro
culberro's Avatar
I'm using the same tank, but using a 450LPH pump, and it's pretty darn quiet.
The SUMP height difference is definitely noticeable though. It's on the drift car and anything less than 1/2 tank and it'll fuel starve when getting rowdy.
I guess it's time to install a fuel surge tank.
Old 03-30-2021, 05:30 PM   #4
Roy probably has an OG tank, I'd PM him first.
Old 03-30-2021, 05:38 PM   #5
2manyturbos
^^ 4 of them. All in good condition.
Old 03-30-2021, 08:57 PM   #6
Jack
junkman
Jack's Avatar
Pfft 8 here
I love you even more Jack.
