Old 03-30-2021, 10:38 PM   #1
sheepbleat
Default Removing a trashed rear spring retaining plate
This bolt/plate has met an untimely demise in my 1991 244. The bolt just spins freely in the plate, and the nut is seized to the bolt.
I’m sure I’m not the only one who’s felt this pain. Also seems like a tough place to fit an angle grinder. Regardless, I’ve got a replacement one and I’m going to attack it this weekend.
What’s the TB preferred method for freeing one of these from a trailing arm? Drill it out? Try and cut it?
Greg
My Feedback Thread
sheepbleat is offline   Reply With Quote
Old 03-30-2021, 11:02 PM   #2
Jack
junkman
Jack's Avatar
grab the bolt with vicegrips
I love you even more Jack.
Old 03-30-2021, 11:21 PM   #3
$599 Volvos
Pry up on the plate while using an impact wrench or driver to loosen the nut.
Chturd - pullyourbootstrapsupandsuckituplooser
Chturd- keepyerfilthyhandsoffMYMONEY
Old 03-31-2021, 01:41 AM   #4
sheepbleat
Awesome. Thanks both.
And while I’m asking... anyone know the threads on these? My heart says M10 x 1.5 but it’s a shot in the dark.
Old 03-31-2021, 04:47 AM   #5
$599 Volvos
I just stuck a regular 7/16" bolt back in its place.
Old 03-31-2021, 08:29 AM   #6
esmth
ah this happened to me. I forget what I did to get it out, but I know the ones that went back in were tack welded together!
1991 244 LH2.4 M46 352k miles
Old 03-31-2021, 01:15 PM   #7
culberro
culberro's Avatar
I'm 99% sure that's the correct size.
I usually just replace them with a nut and bolt when that happens, or tack weld the stud to the plate.
Old 04-01-2021, 03:51 PM   #8
sheepbleat
Confirmed: M10 x 1.5
Old 04-02-2021, 06:15 AM   #9
Otto Mattik
board member
Otto Mattik's Avatar
Old 04-02-2021, 08:56 AM   #10
$599 Volvos
Originally Posted by Otto Mattik View Post
I have a good mix of SAE and metric bolts on my car, after 41 years a few holes get stripped out. Plus I have a big rack of stainless SAE hardware at work.
Old 04-04-2021, 04:27 AM   #11
Otto Mattik
board member
I've been known to do it ..reckon I try to stay oe is to avoid confusion later if I forgets about it ?
