Professional Hack
![]() Right, this isn't a problem yet, but I can see it being an issue in the future, so I figure I might as well ask and order parts now.
So I have a 1967 144S, which originally came with SU carbs. I'm probably swapping to either a 38/38 DGMS or DCOE 45s when I get around to reassembling the (swapped) engine. I understand that the 140s, because of the intake being on the passenger side, has a linkage bar of some sort that runs under the dash. Where exactly am I supposed to attach any kind of aftermarket linkage arms to? I see this nub that pokes out of the firewall, but is it threaded? I also happen to have an IPD throttle cable conversion kit for a DGMS... is that possible to use on a non-EFI car? Sorry for some probably dumb noob questions. Any guidance is helpful.
Doing the wrong thing the right way. Speed parts for sale: http://forums.turbobricks.com/showthread.php?t=359797 |
The Librarian
![]() The DGMS linkage uses the original firewall bushing for the rear of the cross shaft. The front will ride in a heim joint on the manifold.
DCOE manifolds typically have mounts for the cross shaft. With either setup the linkage rod from the pedal connects to an arm on the cross shaft just like with the SU's. |
Professional Hack
#4 | |
Enough already!
![]() Quote:
Differences of opinions should be tolerated, but only if they're not too different. - Sharon Craig |
#5 |
Professional Hack
#6 |
The Librarian
![]() Redline sells linkage kits for the DGV/DGMS carbs. It's not listed on their website so you have to call them to order or buy it from me. I keep them in stock.
They also have linkage kits for the DCOE's but they have a 5/16" shaft with stamped metal arms that can slip if not tightened very tight. ![]() I like the kits that Pierce sells. They use a 3/8 stainless steel shaft with aluminum arms that are much nicer. ![]() |
#7 | |
Professional Hack
![]() Quote:
Eh, I haven't had the best experience with Pierce. Last manifold/linkage set I ordered from them, they gave me the wrong sized eyelets for the manifold, and neither would fit. I contacted them about ordering the correct size, and they told me to call their shop... I'm not into long distance calls. |
#8 |
![]() I would get pedal from 240 and wire from B20 engine.
#9 |
Enough already!
#10 |
Professional Hack
#11 |
![]() “ I'm not into long distance calls.”.
Huh? |
#12 |
Professional Hack
#13 |
Amateur hour!
![]() Dude just have your SUs rebuilt instead of swapping to that miserable Weber, unless you fully commit to the DCOEs.
#14 | |
Professional Hack
![]() Quote:
I already have the functional carbs, just trying to run it before doing anything fancy. |
