Old 04-02-2021, 06:13 PM   #1
RickATL
Family's fleet manager
RickATL's Avatar
Default "simple" keyless entry now going on 2 weeks
Im including a photo and video.
I was going about adding keyless to a 93 244.
Installed a passenger side actuator in the door, but then thought i should clean up the tumbler wires that everyone seems to eventually have a problem with.
I used liquid electrical tape, covered it with heat shrink and everything seemed fine. Now turning the door lock doesnt energize the unlock/lock???
Im thinking i might be off on placement of the black casing around the tumbler? Or any other ideas?
Here is a link to a short youtube video
https://youtu.be/9W708Jdpnd4
Feedback thread: https://forums.turbobricks.com/showthread.php?t=353892
91 245 re-christened “The Mistress” 012021
93 244 "Lars"
92 245 "Astrid"
Past
88 245 "Margit" sold
93 244 completely disassembled - It died, so many of its parts could help others live.
97 855 T5
97 855 NA
RickATL is offline   Reply With Quote
Old 04-02-2021, 06:32 PM   #2
apachechef
Burnt Sierra Madre
Iirc, it can be 180 deg off
Dammit, Lummert.
apachechef is online now   Reply With Quote
Old 04-02-2021, 07:06 PM   #3
volvowagoon
volvowagoon's Avatar
I was curious about doing this. Our 240 came with remote start, but they didn't hook up the remote lock/unlock feature. Knowing how rusty the rest of the car is and how these actuator wires like to corrode, I'm a bit nervous to attempt it.
1986 Buick Grand National - Restoring to stock™
2002 Camaro V6 T5 +T - The trashy car that's fun to drive
2010 C30 T5 - The boring but trusty daily - 192k
1989 245 DL - The boring but not trusty daily - 226k
IG: @v6buick
Old 04-02-2021, 07:15 PM   #4
bobxyz
bobxyz's Avatar
The orientation of the black collar and tabs looks fine. Does it work if you pull up and push down on the unlock knob?
Old 04-02-2021, 07:32 PM   #5
RickATL
RickATL's Avatar
No it does work either way. When i first reconnected it at the 3 prong connector i heard it engage, but now neither the key or pull/push the knob works.
Old 04-02-2021, 07:39 PM   #6
2 old for this
With keyless entry why do you need the key switch?
Old 04-02-2021, 07:48 PM   #7
cleanflametrap
cleanflametrap's Avatar
Does the remote operate the actuator with the door in the same position as you have it testing the key/button switch? The lock is mechanically disabled with the door open.
I have not found a use for the button or key switch since adding the keyless entry, so I've just left them unplugged under the dash where the switch wires are deteriorated.
http://cleanflametrap.com/keyless3.html
-Art
Old 04-02-2021, 08:11 PM   #8
bobxyz
bobxyz's Avatar
Unplug the 3 pin connector and measure the voltages across each pair. Black wire should be ground, and the other 2 are the lock / unlock relay coils. They should be +12v. If good, try jumpering one at a time to black-ground to see if you can manually trigger lock/unlock.
Old 04-02-2021, 10:40 PM   #9
RickATL
RickATL's Avatar
Ive run the ŵires, but havent hooked up the keyless unit yet. But ill màke sure i recheck it closed. Its possible i hàd it open.
Old 04-03-2021, 02:38 PM   #10
RickATL
RickATL's Avatar
Originally Posted by RickATL View Post
No it doesn't work either way. When i first reconnected it at the 3 prong connector i heard it engage, but now neither the key or pull/push the knob works.
EDIT: This morning I was double checking things and after touching the unlock or lock relay (I'm not sure which) it started working as it is supposed to. It promptly stopped working again not 5 minutes later. I have to go through the wires and double check their connections.
Old 04-03-2021, 02:59 PM   #11
OttoB
IIRC, there are three wires red, black and yellow.
Black goes to ground, others to relays. One relay for opening, one for closing. Follow wiring diagram.
Old 04-03-2021, 03:50 PM   #12
nel621
Did you do a good job of isolating the wires before the liquid tape bath? I hate that stuff. You may still have a break in the wires as it passes through the door.
Old 04-04-2021, 10:53 AM   #13
RickATL
RickATL's Avatar
Yes I held them separate with clips while painting one side. After they dried, I then flipped them over and brushed the other side. I then put heat shrink around each. I think it was just a problem with the relay not being plugged in well enough.
