Old 04-03-2021, 01:37 PM   #1
TimS
Default bosch to megasquirt tach input
I'm trying to put a MS2 on a 1984 240 kjet turbo, IC, but don't want to get into ignition control( right now). Can I just go right from the coil or do i tap into the trigger wires from the dist.?
If I use the wires from the dist. do I just tap into each wire and back to the computer
at VR1 and Vr2, with it still connected to the bosch black box?
Tim
TimS is offline   Reply With Quote
Old 04-03-2021, 01:52 PM   #2
bobxyz
bobxyz's Avatar
Normally, for fuel-only, you tap off the coil negative "-" tab. You need to build the MS2 Coil Negative circuits.
I don't know how Bosch Breakerless connects the 2 VR signals from the distributor. If it grounds one of the signals, you might be able to tap off the other VR wire to MS. (MS expects one of the 2 VR wires to be grounded.)
Old 04-03-2021, 07:34 PM   #3
TimS
it is actually a microsquirt, so its ready for both. The manual says the same thing about the - side of the coil, but i mentions not to do if its a CDI unit. I'm not sure if that's the same as what a Bosch system is. I was hoping someone would say that they've run MS like that.
Old 04-04-2021, 10:25 PM   #4
bobxyz
bobxyz's Avatar
MicroSquirt is easy - connect the Opto +/- wires to the 2 tabs on the coil -/+ (they cross Opto+ to - tab).
CDI is the same thing as an add-on MSD red high-voltage multi-spark ignition box, not the factory Bosch Breakerless ignition.
Once you want to go beyond Fuel Only, you'll need a LH2.2 distributor, or will need to modify the Turbo K-Jet distributor to lock down the vacuum and centrifugal advance mechanisms.
Old 04-04-2021, 11:42 PM   #5
Dirty Rick
Dirty Rick's Avatar
I think You can also trigger the MS off the tach output of the power stage.?
