Old 04-03-2021, 04:58 PM   #1
Msi
Default Ford 2.3L Lima MS + Harness - can it work for stock 940 2.3T?
Hello fellow TBs,
I found this -
https://www.stinger-performance.com/...t-pnp-2.3-ford
"Microsquirt Plug & Play Standalone Engine Management + Harness for 2.3L"
This is for the Ford Lima 2.3L engine, N/A and Turbo.
For 650USD it includes:
-Microsquirt EFI Controller
-Complete Engine Harness
-3 Bar MAP Sensor
-Intake Air Temp (IAT) Sensor
-MAP Hose
-Base Tune
-Startup Guide (11 pages)
I ran an inquiry with them about the harness and they replied:
"The harness is wired for a factory Ford coil and a tfi distributer not your crank sensor. All microsquirt wires exist in our harness"
My questions are:
How complicated would it be to adopt this to a stock 2.0/2.3 940 Turbo?
Does the price seems fair for the deal?
Thanks in advance!!
Msi is offline   Reply With Quote
Old 04-03-2021, 05:51 PM   #2
Sir Bricks-A-Lot
Sir Bricks-A-Lot's Avatar
If you're really looking for a plug & play setup, why not support a forum member who has a proven solution?
http://forums.turbobricks.com/showthread.php?t=144251
Sir Bricks-A-Lot is offline   Reply With Quote
Old 04-03-2021, 06:13 PM   #3
Msi
In fact, I have already acquired a PnP setup from Kenny.
There is a difference between the two solutions though - what I've posted is a full standalone harness that does not make use of the 20+ year old original LH2.4 harness.
Old 04-03-2021, 07:22 PM   #4
90volvo
Kennys pnp is top notch. Ive ran the pnp was simple to hook up and he was quick to answer any questions.
B230ft rebuilt -MS-Turbo-E85
1985 240 Work in progress.
Old 04-04-2021, 02:55 AM   #5
Msi
Absolutely agree.
I'm looking into a full standalone harness because I'd like to remove all OEM electronics from the car and I'm too lazy to build a harness from scratch.
Hence the question I posted.
Old 04-04-2021, 03:28 AM   #6
mocambique-amazone
Buy a 240 LH2.4 loom new and the ms from Kenny: done
Old 04-04-2021, 09:31 AM   #7
90volvo
Originally Posted by Msi View Post
Absolutely agree.
My car had an engine fire when I was running PNP play from kenny. Instead of buying another harness, I built mine. It wasnt hard but time consuming, it helped me learn alot about MS. If you dont want to build one, I bet kenny would put one together for you. Just my guess. That ford harness does look tempting though.
Old 04-04-2021, 11:18 AM   #8
h20ham
I had contacted Stinger months ago, hoping they could make a Duratec work. The Lima is strong, 50 years ago.
Without the headaches of MS, there dont seem to be any easy answers.
How did you get here
h20ham is offline   Reply With Quote
Old 04-04-2021, 03:14 PM   #9
rb92673
Yoshifab might have a plug and play Microsquirt harness for LH 2.4 that doesn't use the existing loom. I saw one for LH 2.2 he was testing.
Old 04-04-2021, 07:40 PM   #10
Msi
You mean something like this ?
https://www.classicswede.co.uk/LH24_..._17591997.aspx
Old 04-04-2021, 07:42 PM   #11
Msi
Now why did I not think of that. Great advice!!
Old 04-04-2021, 07:52 PM   #12
Msi
Didn't find any alike. Have a link?
Old 04-04-2021, 10:36 PM   #13
bobxyz
bobxyz's Avatar
The 8 foot MicroSquirt harness from DIY has nice labels on every wire. This makes building the harness easier.
While the Ford plug&play harness might work, I'd expect that there will be excess wire length in some places and not enough wire length in others, unless the manifold and sensor locations are very close between the two engines. In other words, it may look ugly and will still require modification to fit.
Old 04-05-2021, 04:21 AM   #14
Msi
That's a good point.
Old 04-05-2021, 10:51 AM   #15
rb92673
info@yoshifab.com
or try Kenny
or just order the 8' harness and all the connectors and sensors from Rockauto and make your own.
Old 04-05-2021, 02:15 PM   #16
bobxyz
bobxyz's Avatar
FYI - if you don't like the look or robustness of black split loom harness wrap, you can buy high-temperature non-shrink harness tubing by the meter from digikey - search for: Raychem NETM1000. It's flat black, instead of shiny, and only goes up to ~1/2" I.D.
Old 04-05-2021, 05:46 PM   #17
Msi
Oh man, I was not aware of Rockauto. Thank you!! This makes me a happier TB owner
Old 04-06-2021, 11:14 AM   #18
rb92673
If it makes it easier, here are the sensors and connectors I ordered from Rock Auto:
DELPHI PS10081 Manifold Pressure (MAP) Sensor
DELPHI TS10077 Air Intake / Charge Temperature Sensor
WVE/AIRTEX/WELLS 1P1016 Air Intake / Charge Temperature Sensor Connector
STANDARD MOTOR PRODUCTS HP3980 Fuel Injector Connector
BOSCH 0280122001 Throttle Position Sensor (TPS)
WVE/AIRTEX/WELLS 1P1421 Throttle Position Sensor (TPS) Connector
I don't know how to connect your sensor for flywheel position.
Old 04-06-2021, 12:21 PM   #19
culberro
culberro's Avatar
Prowire USA has all the bare connectors for substantially cheaper if you want a clean install, and you get neat heat shrink labels for everything:
https://prowireusa.com/c-84-misc-connector-kits.html
https://prowireusa.com/p-3723-4-cyl-...-90-boots.html
