Old 03-02-2021, 04:14 PM   #126
R-Pow3R3d
Master of Disaster
R-Pow3R3d's Avatar
Originally Posted by jstblz View Post
I have family in the Cranberry area. Hopefully we can link up this summer.
That would be awesome. I better get the 740 cleaned up. lol
1990 745 Turbo Intercooler
2007 XC90 V8 Sport
2007 XC70
R-Pow3R3d
R-Pow3R3d is offline   Reply With Quote
Old 03-15-2021, 02:30 AM   #127
jstblz
jstblz's Avatar
Time for a quick update...
Added 3M paint protection film (shiny part) to certain sections of the cage to to save the paint from entry and exit wear.
Washed junkyard carpet and sprayed and brushed in between coats of SEM color coat in Landau Black. It's even darker in person.
Wrapped the downpipe in PTP's Lava wrap
*DRUMROLLS* Final wiring started!!
Mounting plate for new fuse panel
Great accessibility here
Decided to get a grounding block to organize the grounds and not stack them all under 2 screws. The bottom lug was connected with 8GA to ground. This will be the ground for most things on the dash. Using a separate ground for the stereo and instrument cluster. Any issue with that??
Even re-taped the accessory connectors
Using this bluetooth, marine Kenwood unit for the stereo system. Mounting the amp under the passenger seat
84 242 TIC
jstblz is offline   Reply With Quote
Old 03-15-2021, 06:28 AM   #128
JerryJS8
der Junge
JerryJS8's Avatar
Nice, I like the hidden and minimalistic radio install!
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 03-18-2021, 09:57 AM   #129
jstblz
jstblz's Avatar
Same here! I use my phone for GPS and music so no need for a disc or heavier screened unit.
Old 03-18-2021, 01:01 PM   #130
DET17
Reformed SAABaholic
Regarding the quality of your grounds...... simply measure resistance from those junction points back to the battery NEG terminal. If you've got marginal grounds, you will see it on your Ohmmeter.
Old 03-18-2021, 01:33 PM   #131
jstblz
jstblz's Avatar
Ok, makes sense. I'll verify and update.
All good! Thanks
Old 04-15-2021, 01:35 PM   #132
jstblz
jstblz's Avatar
So work/non-car life has been kicking my butt lately, but progress has been made.
I'm putting some things back together
Doubled up some black speaker felt to cover where the old reels went.
Looks like it'll do
Made some thumb nuts for my VDO external temp gauge.
GPS antenna for the RaceCapture/digital dash integration. It comes with one, but it sits on your dash or magnetized to the top of the car. Seeing as though this will be an important system, I decided for something permanent and nice.
The wire from which will run down the roof and to the dash behind the filler panel to the RaceCapture module.
Getting dangerously close to the final design of the touchscreen panel. That'll be the next big update. Looking like I may be good for inspection and tuning by mid May.
Old 04-19-2021, 05:01 PM   #133
jstblz
jstblz's Avatar
Default Instrument cluster
It's all based arounnd this Raspberry Pi 3 in an aluminum case with built-in fans.
This board from Mausberry that safely power on and shutdown when the car is turned on and off.
I also mounted the entire case to the screen.
I made a quick and dirty surround for some earlier testing, but I ended up scrapping that
So I designed something better...
This will eventually get printed in the black heat resistant filament.
Old 04-21-2021, 10:43 AM   #134
aidanahunter
aidanahunter's Avatar
Very nice
aidanahunter is offline   Reply With Quote
