Old 08-11-2017, 03:13 PM   #1
91racked
Default Do you recognize this wheel?
I reaaallly like these wheels, I want to get a set, if anybody could tell me what they are that would be fantastic.... Saw them on a low 242 on my way to work and now i cant stop thinking about them lol. Thanks!
91racked is offline   Reply With Quote
Old 08-11-2017, 03:26 PM   #2
Jack
junkman
Jack's Avatar
that's a VW wheel
Old 08-11-2017, 03:35 PM   #3
Pro Sneaker Peddler
that's a Peugeot wheel
FTFY
https://www.oponeo.co.uk/steel-wheel...-9697#19715690
Old 08-11-2017, 03:36 PM   #4
Dirty Rick
I think they are custom made.
Strange offset.
Usually the wheel center is welded to the center hump, those are welded on inside of the hump on the inside lip.
Old 08-11-2017, 03:42 PM   #5
Pro Sneaker Peddler
Strange offset.
Cut, flipped, rewelded, painted. Common in Sverige.
Old 08-11-2017, 03:43 PM   #6
Jack
junkman
Jack's Avatar
I know it was a joke
Old 08-11-2017, 03:45 PM   #7
Pro Sneaker Peddler
This isn't OT.
Old 08-11-2017, 03:47 PM   #8
Jack
junkman
Jack's Avatar
This isn't OT.
oh excuse me sir.
don't point your fingers at me
Old 08-11-2017, 03:49 PM   #9
Tuff240
240 Ninja
Tuff240's Avatar
That link you posted shows round holes. The OP's pic has oval holes.
-Patrick
Old 08-11-2017, 04:00 PM   #10
centason
Wine enemas for all
centason's Avatar
It was a joke.
Peugeot 407.
Member: TBCCS
"Let's not burn the universities yet. After all, the damage they do might be worse." -H. L. Mencken
Just remember this guys. Im related to cocaine.
they were pushing sloppy poo up a steep hill with a pointy stick.
You sons of bitches are the biggest thread de-railers in forum history.
Any forums history.
centason is online now   Reply With Quote
Old 08-11-2017, 04:15 PM   #11
Pro Sneaker Peddler
I shall be executed on the spot.
Old 08-11-2017, 04:15 PM   #12
matt b
Check out this thread: Explanation here
TL;DR: Wheels are originally 17" Peugeot 407 steelies, widened to 8½" front and 9½" rear. Tires are Falken FK452, 215/45-17 front and 235/40-17 rear.
Old 08-12-2017, 01:29 AM   #13
91racked
I saw your link to the new peugot wheels. I dont really care about the deep dish look, i just want a 17" wheel with holes like that.
Will these just fit or do they need spacers? https://www.oponeo.co.uk/steel-wheel...-9697#19715690
Other similar options? Im in the US.
Maybe something in the junk yard would fit?
I have the IPD lowering springs and swaybars...
should go for a 15" with a smaller tire?
Im after performance. Not looks.
I'm gonna be hanging it out pretty hard in the corners...
I don't want to roll any tires off the rim. And I dont want to rub.
or should I just pick out some s60 wheels? I dont mind buying spacers for them. I just prefer the steelie look.
Old 08-12-2017, 01:37 AM   #14
centason
Wine enemas for all
centason's Avatar
Like in the picture? No. Not that nice. There are diamond racing wheels, but those pictured wheels are 100x better. Dodge has 17" wheels. 55superbeetle had some on his 242. They weren't modified.
Old 08-12-2017, 02:07 AM   #15
Tuff240
240 Ninja
Tuff240's Avatar
All the 15" tires will suck unless you go with a 225/50-15 DOT race tire.
You want it to handle well and you don't care about looks, but you want heavy steelies or stock cast aluminum wheels? Makes no sense.
Lightest 17x8 you can find with 235/40-17 sticky tires. You can squeeze 245 width tires on a wagon (you didn't specify what type of 240 you have) with out rubbing with some effort. Might rub occasionally on a 242, but if the offset is perfect it would be a light graze and shouldn't hurt anything.
And you'll never go as fast on the street as you can on a track, so your version of "hanging it out pretty hard in the corners" is most likely very tame.
Old 08-12-2017, 02:17 AM   #16
91racked
they can be 35 colors and rusty, I'll paint them lol
Old 08-12-2017, 02:21 AM   #17
91racked
Makes plenty of sense. I Don't care what they are made out of.. I just dont want to roll a tire off a rim for the THIRD time.
Not trying to crash here. And iim not trying to spend 3000$ for rims on a 350$ car.
also , 91 4 door.
Old 08-12-2017, 02:29 AM   #18
Jack
junkman
Jack's Avatar
Old 08-12-2017, 02:31 AM   #19
Tuff240
240 Ninja
Tuff240's Avatar
also , 91 4 door.
Sounds like you weren't running enough tire pressure.
17x8 or 17x8.5 Enkie RPF1's (use adapters) are pretty easy to find on CL. Strong and light. You'll want a set with high offset so you can use adapters. Something in the et32-40 range would work.
SSR Type C's would be great too, but they are a little harder to come by.
Old 08-12-2017, 02:40 AM   #20
91racked
what, 40 psi isn't enough?
Old 08-12-2017, 02:56 AM   #21
Tuff240
240 Ninja
Tuff240's Avatar
If you are running 40psi, something else is going on. Cheap off brand tires? Chrome wheels? Something isn't right.
Old 08-12-2017, 09:07 PM   #22
okoye
okoye's Avatar
I have 215/45/17 on a 17x10 I keep my pressure between 40-45 and I slide the car when I get a chance. Never had a tire come off that had good pressure. The only time i had a tire come off was when the tyre pressure dropped to 5 psi
