- Nov 19, 2002
- California
Use that test lamp to check injector pulse. You could hook one end to positive and the other end to the injector control circuit (negative).
You are getting close now that you found a no spark with a timing light. (Secondary ignition)
Put a test lamp between coil negative and ground. Blink while cranking? Yes= your circuits before the coil are are working (primary ignition)
