That is the conclusion I reached, too. I could never picture how this ball joint holder would increase camber.Also those shouldn't increase your camber at all, they just recenter the ball joint when you run increased camber.
Factory ones are good, it's the aftermarket crap that you have to worry about. I'd love some more camber, but I'd also love some ride/noise compliance and years and many many miles of no issues.
On a lowered car, the chassis side of the control arm is low and the ball joint side is high. That's why we add spacers between the strut tube and the ball joint to lower the ball joint side of the control arm. These spacers drop the ball joint like we want on a lowered car, but this will introduce bump steer if the tie rod and/or rack is not spaced accordingly.Maybe I'm visualizing this incorrectly, but it seems that these extender plates make the control arm angle even higher on a lowered car. With a spacer between the spindle and balljoint, you're moving the control arm down, but this plate moves it up.
Killing in what way? New or used? Broken, or just splitting & clunky?Mine are not noisy or nasty in any way. They had about 50k on them by the time I parked the car. I was killing volvo mounts at around a set per month. That gets frickin expensive.
Not sure if you're referring to regular balljoint spacers or the ones in this thread.
The spacers in this thread aren't dropping the ball joint. They're moving the control arm up.
I see now. I was visuallizing the spacers and didn't go back to look at the pictures again.Not sure if you're referring to regular balljoint spacers or the ones in this thread.
A better solution would be to weld some thick material to the control arm that would allow for new holes for the ball joint to be attached on the same plane, only moved out farther such that it increases track width and negative camber. There was a for sale ad a few months ago for some modified like this.
My friend did the same by welding on a piece of flat steel the same thickness on the and of the control arm. Conformed to the same shape and filled the bolt holes and re-drilled them. Its actaully very effective and easy. The only hard part is exending the tie rod as well. we were gonna try and see if we could source another tie rod that would be an inch longer.
The angle of the control arm surface is irrelevant in comparison to the straight line drawn between and inner pivots and the outer ball joint
If you make the control arm longer, and the angle stays the same, then the ball joint rises, simple as that. It's a triangle, you should know that
I made a bolt on spacer...I'll post pics when everything is all finished.
Downside is the you gotta extend the tie rods.
I would like to see this. And I can look into options for longer tie rods, there might be something available over the counter.
But the place of the ball joint in space is dictated by the strut tube and tire height.
Sure, as you push it forward the whole strut assebly will move in an arch pivoting from the top mount, and it will thus rise a bit in relation to the car, but the difference here will be miniscule.
But in reality the ball joint will remain almost at same height from the ground, as will the inner pivot point, Thus the line will remain virtualy the same, only longer.
The fact that it is longer does have some effect on the roll center position once the suspension moves. Static roll center will not move any significant amount.
EDIT
except...
if you move the lower ball joint outwards, the car also becomes slightly lower, as the lenght of the strut assembly will remain the same, which means that the line between the inner pivot point and the ball joint will be angled as well compared to stock configuration???
Change in height will be very small though.
Aargh, space is difficult.
EDIT EDIT:
In the lower picture the lenght x, being the lenght of the strut assembly remains the same, as it should, and the control arm becomes longer, as it does, so the line between pivot points will also be in an angle compared to stock.
Right?
The upper is not possible, unless at the same time the strut assembly is made longer.
The pictures are highly exaggerated, in real life the changes made are smaller in this case.
Ok...not to be a dick or anything...BUT...
What does all this babble mean...sum it up for the retards that spend more time doing stuff than talking about it.
It means you get more camber and wider front track which are pluses if you can tune the rest of the car to them. BUT you still have screwed up geometry because they would not move the control arm down. Visually they will move it up (wrong direction we want to go), but this does not change the geometry much in this case because there is an imaginary line from the inner pivot point (the bolt through the cross-member) to the ball joint and you haven't really effected this much.Ok...not to be a dick or anything...BUT...
It also means you have to re-adjust your car overall to account for the wider front track as this will make it more tail happy now. You could widen the rear track with spacers to offset the difference. That would probably be the easiest solution.
