Old 08-18-2018, 03:49 PM   #26
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
You should be able to get to the bolts for the adapter via the starter. I'd bolt the adapter to the converter before mounting the transmission. Then bolt the flexplate to the adapter by rotating it and getting it before bolting the starter up.
Old 08-20-2018, 12:26 PM   #27
TurboDenny
Why am I here?
This morning I drilled the flexplate out for the adapter to bolt to and I ran into an issue. The adapter pattern is too small to get the bolts in once the flexplate is bolted to the crank. You can reach them if the oil pan is off, but I'm not gonna drop the oil pan every time I need to drop the trans.
Seems like we might need to wait for an adapter made for whiteblocks to come along. I unfortunately don't know anyone locally capable of producing one, but I'd be willing to supply parts/time if I did.
Instagram: @itstotesdenny
Old 08-20-2018, 12:56 PM   #28
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Roger should be able to work something up if it's just a difference in bolt pattern. Have you tried contacting him yet? Maybe let him know you're up to being a guinea pig? lol
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 08-20-2018, 01:33 PM   #29
Hank Scorpio
already did
Old 08-20-2018, 01:40 PM   #30
TurboDenny
Why am I here?
I sent him and e-mail earlier. We'll see what he says.
The entire diameter of the adapter will need to change.
Old 08-20-2018, 02:12 PM   #31
lummert
lummert's Avatar
Slot the bolt holes in the flex plate?
Old 08-20-2018, 03:32 PM   #32
Hank Scorpio
Originally Posted by TurboDenny View Post
This is the vertical adapter.
The converter is sitting all the way back in the photos. The Gap is a bit larger than it looks, ~.300" or more. I'd like to see half that.
The issue I'm seeing is getting the spacers in place. The adapter is designed to be bolted to the converter first, then bolted to the flexplate. Getting the spacers lined up while threading the bolts in will be a tedious task. Ideally this would all be one piece
I agree 1 piece would be nice but I just reread this and realized you want to put your spacers between the flexplate and the adapter. Why not between the adapter and converter lugs? Looks like the lugs won't clear the tone ring anyways.
Old 08-20-2018, 03:40 PM   #33
TurboDenny
Why am I here?
The pilot for the converter would not reach the adapter if I did it that way. Yet another thing you'd have to machine.
Roger specifies that his adapter only work with 10.75" pattern converters for that reason. The converter pictured is not the one I will be using. Simply had it for mock-up.
Old 08-21-2018, 10:29 AM   #34
Roger-Dee
is DeeWorks.ca
Roger-Dee's Avatar
Hi guys!
I do have a whiteblock flexplate in stock and all of the measurement from the redblock adapter. It would be really simple to make a new one to adapt both half.
Can you get me how much thicker it would need to be to reach the converter? I'll see what I can mock up with what I have here.
Cheers!
94 944T - 16v turbo - 12,14@122
Lm7 5.3, S475, Ms3Pro, 4l80e - 10,36 @ 134 / 6,70 @ 107
www.deeworks.ca
Need T5 Adapter? T5 Speedometer Plug? Gm Torque Converter Adapter? Freeze plug retainer? HE351 solenoid plug? Pm me!
Roger-Dee is offline   Reply With Quote
Old 08-21-2018, 11:53 AM   #35
TurboDenny
Why am I here?
Let me get out in the garage and make some measurements
Edit: Gap from converter to adapter is ~.360"
Old 08-21-2018, 01:49 PM   #36
Roger-Dee
is DeeWorks.ca
Roger-Dee's Avatar
That's with the converter fully in the trans? Or you did account some play to back out the converter?
Old 08-21-2018, 02:24 PM   #37
TurboDenny
Why am I here?
Should have clarified, that is fully backed into the trans.
Old 08-21-2018, 07:21 PM   #38
Hank Scorpio
You might as well throw one on my tab too Roger. ;)
Old 08-21-2018, 11:02 PM   #39
Roger-Dee
is DeeWorks.ca
Roger-Dee's Avatar
Old 08-22-2018, 10:17 AM   #40
gsellstr
Vintage anti-ricer
gsellstr's Avatar
By the time your done Doug, you'll be cheaper just driving up to pick up your pile. lol
Old 08-22-2018, 10:50 AM   #41
Roger-Dee
is DeeWorks.ca
Roger-Dee's Avatar
Hey that's an awesome idea! :P Everyone is more than welcome for a shop tour ;)
Old 08-22-2018, 01:59 PM   #42
Hank Scorpio
lol 2992 miles each way. I don't have that much stuff
Old 08-22-2018, 02:45 PM   #43
gsellstr
Vintage anti-ricer
gsellstr's Avatar
yet...
Old 10-23-2018, 09:44 AM   #44
Hank Scorpio
Just bumping this to see there’s any news. I know Roger hasn’t yet but did Denny home brew a solution yet or are we in a holding pattern?
