Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Hello Guest, welcome to the initial stages of our new platform! You can find some additional information about where we are in the process of migrating the board and setting up our new software here
I have them installed, the side markers are on as daytime running lights. as well as they blink alternately with the turn signals. not sure if thats normal or I did something wrong.
You have done what a lot of people prefer to do, but it is not how the cars are set up from the factory. I wouldn't call it wrong, and many people think of it as safer because your side marker light serves as a running light from the side and still flashes as a turn signal. Stock setup is dark unless it is flashing with the turn signals.
I would guess that you added side markers with some scotchloks and tapped into the turn signal wire and the parking light wire (instead of the ground wire). So you get running light when the turn signal is off and it flashes alternately with the turn signal. If you want them to just flash with the turn signals then you need to remove the connection to the parking light wire and move it to the ground wire or ground it to the convenient ground terminal block on the fender with a spade connector.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
