Old 01-16-2015, 01:17 PM   #1
Default BNE Update: 240 Split Brake Line Brackets
Just finished a production run on a new product. An easy and reliable way to clamp the stock brake lines in place on a 240 that doesn't require separating the lines or zipties to remove and install the front strut housings.
Now currently in stock and shipping! http://www.kaplhenke.com/collections...e-line-bracket
240 brake lines, #IDFWU
When you install them, you can listen to this song.
https://www.youtube.com/watch?v=ZR_X6PrASho
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 01-16-2015, 01:41 PM   #2
sim
Mere Drab Mob
sim's Avatar
What a great idea!
And, your link is broken.
I have a Volvo with some half-done, homemade crap in it.
http://forums.turbobricks.com/showthread.php?t=244534
sim is offline   Reply With Quote
Old 01-16-2015, 01:41 PM   #3
Originally Posted by sim View Post
What a great idea!
fixed!!!! thanks for the heads up
Old 01-16-2015, 02:43 PM   #4
Stiggy Pop
Stiggy Pop's Avatar
Also Ben said if we found 14 more people who would be interested in a single line version (for the ABS guys), he could do a run!
'79 242
943 pickup
Old 01-16-2015, 02:45 PM   #5
I got one other person requested it so you're down to 13.
Even though these will work fine with only 1 line clamped...
Old 01-16-2015, 02:47 PM   #6
brendon_ak
Any chance you could make the clamp surface interface with the spline style fittings I got?
Great looking product!
Old 01-16-2015, 02:58 PM   #7
If your willing to pay 2,000 for a set of brackets I'm sure i could get the right broach and setup to machine 1 set.
Might be cheaper to get lines that would work with these if you want to use them.
Old 01-16-2015, 03:00 PM   #8
DarkKratoz
DarkKratoz's Avatar
Neat-o burrito!
1995 Volvo 960 - Absolute turd that I despise
DarkKratoz is offline   Reply With Quote
Old 01-16-2015, 03:33 PM   #9
propav8r
F*ck Edgar
propav8r's Avatar
U da real MVP
nipple farts
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 01-16-2015, 05:22 PM   #10
towerymt
the real Towery
towerymt's Avatar
Looks good, but I'm sticking with the Rob Prince method.
Old 01-16-2015, 05:38 PM   #11
yep, definitely a free way to do this with just cutting the tab.... but some people just want something a bit nicer.
Old 01-16-2015, 06:00 PM   #12
wisturbo
wisturbo's Avatar
+15 ft-lbs
wisturbo is offline   Reply With Quote
Old 01-16-2015, 06:21 PM   #13
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
The price for such a nice piece isnt that bad at all. It's not a needed piece but a very very nice piece. Very slick.
Old - Gen3 4.8/SS1/Cast VSR 7875/Deka 80/single walbro 450
60' 1.66 - 1/8 6.53 @ 113.3mph - 1/4 9.99 @ 140.4mph - 20psi 11.5deg timing E85
New - Gen4 5.3/SS2/Cast VSR 7875/Deka 80/single walbro 450
60' 1.60 - 1/8 6.48 @ 112.4 - 1/4 xxx
3140lb no driver
3320lb with driver
Old 01-16-2015, 06:27 PM   #14
Yes, I agree.
Definitely a nice piece but not a necessity,,, but neither is 300 hp in a 240 but that doesn't stop many people from trying.
Old 01-16-2015, 06:37 PM   #15
mopar318
mopar318's Avatar
Originally Posted by blkaplan View Post
Yes, I agree.
Its seems like it would be a necessity with your new housings, right?
Pimps out interiors.
1980 242 16 valve turbo
2007 V70R
mopar318 is offline   Reply With Quote
Old 01-16-2015, 06:43 PM   #16
Yes, If you use the stock style brake line setups.
Old 01-16-2015, 06:46 PM   #17
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Yes, I agree.
I'm very much thinking about buying a set because of having to disco the brake lines to pull the strut. I like that you're fixing problems people didn't even realize they had. Love it
Old 01-16-2015, 10:44 PM   #18
Volvorules
Has a Built Trans!
Volvorules's Avatar
Like.
Sexy setup though, BNE!
Rob
Volvoless
how psi a stock can support?
Originally Posted by MrBill View Post
not even thieves like 7/9 series.
Volvorules is offline   Reply With Quote
Old 01-16-2015, 11:57 PM   #19
wisturbo
wisturbo's Avatar
-50 ft-lbs for no torx and metric tapping. Why an antique bolt and nut? Why not tap that piece you made?
Old 01-17-2015, 01:58 AM   #20
taping into the aluminum adds cost, adds alot of thickness, and is less durable for repeated installation and removal. Really a no win situation. Trying to keep these things as cheap as possible while still being a nice part.
So yea, good suggestions for amateur hour. Next?
Old 01-17-2015, 08:31 AM   #21
mopar318
mopar318's Avatar
You should switch to these.
Old 01-17-2015, 09:09 AM   #22
****, why not just leave a set of vise grips attached. #BTB (because turbo bricks)
Old 01-17-2015, 02:03 PM   #23
slow240
Home Schooled
slow240's Avatar
lol Ive ordered 3 sets, I can't wait to see them. Ill post a review
Old 01-17-2015, 04:14 PM   #24
Old 01-17-2015, 04:24 PM   #25
Old Iron
I Roll
Old Iron's Avatar
Sweeeeeeeeeeeeeeeetttt!
Turbobricked
