So I had to drop the tank to get the vent line hooked up, but it was pretty painless getting it out the second or third time......
Built the last remaining fuel line and have it done and tight.
So with that done I turned to doing the odds and ends, but first, I gave the garage a little clean up.
Started by sorting through the wiring on the drivers side, figuring out what was what, what needed to go to the passenger side since I am doing about 50% or a wire tuck.
I ended up pulling the wiring for the windshield washer squirters and level sensor back into the cab, I dont expect to be using them but wanted to keep in case they are ever needed so they are labeled and tied up under the dash.
Headlights, turn signals, side marker lights, and both of the electric fan wires run up the passenger inner fender well, everything got grommets and the same braided wire sleeving and p clipped to the inside of the fender bolts. It was a total pain the ass.
I had to come up with a solution for the messed up wiring for the lights and the ****ty factory volvo connectors. So I eliminated the connector, replaced all of the wiring and installed weatherpack connectors.
I also ditched the factory horns in favor of a donor horn from the van, it sounds awesome, its the rest of the wiring here, the horn got a tidy little bracket and mounts right behind the grille, factory plug on it too.
With the passenger side wrapped up for the most part, it was onto the drivers side, I got everything run out the factory rubber and laid it all out figuring out where my take outs needed to be and tidied it up as much as I possibly could. This is a time consuming process for me as I want it to be just right. All of the factory connectors came apart so glue style heat shrink could be installed. I think the finish product comes out well.
Here is what I ended up with on the drivers side, I believe I have one last wire to run, hot from battery to the distribution panel. Bracket was powdercoated, plastic got SEM Trim black out of a hot can to keep the spray pattern super fine and gives it a slight texture.
This is just about 100% wired and plumbed at this point. The only thing remaining is the power lead to the distibution panel and some braided sleeving on the starter signal wire.
I have a few loose ends to tie up on the interior, might need some pointers on a few connectors I dont recall where they go.
I need to run one wire back to the trunk for the fuel pump but I think that is about it for big wiring.
If I had wheels this bitch could hit the road in a few weeks.
Sean
