Sweet, thanks! I'm going to pull those injectors for an inspection later today, and if I have a leak I'll swap in the known good injectors with new seals! I feel pretty good about my diagnosis as I have been daily driving this car and have had time to study it's symptoms. I replaced the FPR when I first got the car, since it had a fuel smell in the vacuum line. The car will always fire right up when cold, sometimes with a telltale puff of black smoke out of the exhaust. Now that it is summer and quite hot if I drive the car at all and stop, say for gas, or whatever... When I come back to try to start it it will crank and crank and crank, and eventually start followed by the smell of raw gasoline and black smoke that clears up almost instantly. I found that if I open the throttle while cranking in this condition it will help to get it started. When started it always runs like a top. On one particularly hot day I had to disable the fuel system, crank for a good 30 seconds, re-enable the fuel system, and then it fired up. The reason I suspect a leaky injector instead of the coolant temperature sensor is because when I shut her down hot, I can immediately crank it up and she fires right up, it takes a few min of sitting (leaking) before she is flooded and hard to get started again.
