Old 01-08-2010, 02:18 AM   #1
stasis
stasis's Avatar
Default stall after driving shortly
ill list the following parts recently changed and we can go from there:
head gasket
new/used 15g turbo put on
mani ported
timing belt
coolant temp sensor
intake mani gasket
valve cover gasket
plugs
wires
cap
rotor
all vacc lines
most fuel lines(couple left but seems ok)
removed charcoal canister
removed cruise control(was broken anyways)
that was about the long and skinny of replacing the head gasket and putting the 15g on
so after i got done with that all was well...for a bit.
Drove for about a day then started to sputter and idle low, give it gas and no power sputter and pop then stall, but it would start back up, finally it stalled and wouldnt start for around an hour. I had it towed home and thought the crank position sensor is the culprit, came in the mail today installed it and idled fine all was good i thought till about 5 min of driving it started the sputter again,lack of power almost like it is not running on all cylinders, stalled down the road far enough i had to have it towed...again.
So im just about done ****ing with this damn car as i need a daily driver and its been a piece of lawn furniture for about a month now, any ideas as to whats causing my problems?
My ideas are as follows:
Fuel pump buzzes every turn of the key so i am not thinking thats it.
Possible clogging or clogged fuel pump? would explain why after it sits for a day it starts and idles fine till i drive it and give it gas
coil issue maybe?
do 940's with LH 2.4 have radio supression relays? if so where are they?
im just about out of ideas and patience and need some help desperately, else i have to take it to a shop and pay out the ass to fix it which i really dont want to do...
Thanks in advance turbobricks keep the brick alive!
1992 940t - sold
2008 Z06 corvette
550 hp of fun =)
stasis is offline   Reply With Quote
Old 01-08-2010, 09:28 AM   #2
rstarkie
I do not think the symptoms fit a defective radio suppression relay, but it deserves a look:
Photobucket
While the symptoms don't seem right for the ignition amplifier I would swap a known good one in just to be sure. You do not even need to unscrew it from the drivers inner fender- just unplug the connector and plug it into the known good one. My experience with amplifiers is that the car simply dies without sputters or misses- only to restart and do the same thing again after it cools for a short time
Good luck
Randy
rstarkie is offline   Reply With Quote
Old 01-08-2010, 09:50 AM   #3
MrBill
fige=500Dollar Mistake
MrBill's Avatar
Maybe intake gasket?
I'll bet some sort of vac leak. Any check engine codes?
Someone say crazy rays?
Old 01-08-2010, 01:01 PM   #4
fcpgroton
fcpgroton's Avatar
I am thinking some kind of vacuum leak also. The smallest leak seems to cause all kinds of odd issues with these cars.
FCP Online Support Team
FCP Euro - European Car Parts Specialists
FCP Import - Import Replacement Car Parts
fcpgroton is offline   Reply With Quote
Old 01-09-2010, 02:07 AM   #5
stasis
stasis's Avatar
well when it does start it idles perfectly fine and hold steady vacuum at around -20 or so if i remember right same as it always did, and if it was a leak why would it start and drive fine shortly then act up if it was a leak i would imagine it would be a persistant problem yeah?
i think the battery is dead atm so ill jump it and get codes tomorrow
also will try the ignition amp tomorrow, will head to the junk yard and pull some and try it out any more ideas are appreciated!
Old 01-09-2010, 03:08 AM   #6
Fuel pump relay, power stage, radio relay are all suspect. You need to first check for spark when car won't start. Timing light is safest. Tonight I checked spark at coil by unplugging it and holding wire close to terminal while buddy cranked. Or get a remote starter switch.
Too much to type on mobile. Check my recent thread in maintenance and check brickboardfaq FAQ.
Old 01-09-2010, 07:10 AM   #7
stasis
stasis's Avatar
power stage and radio relay are my ideal culprits also i tried 5 diffrent fuel pump relays 2 known working ones and no change ive had these go out on me before and i know how they act =)
thanks for the input
Old 01-09-2010, 03:06 PM   #8
Like I said check for spark when it's dead. If u have spark, pull the fuel rail and reground the wires and crank engine and check for fuel spray. That will check injector pulsing and an idea if your fuel pressure is ok. Or plug in noid light from IPD and check for flashing or ug in spare injector and feel for clicking. If you have spark and injectors firing check fuel pressure. Good luck and post back with results!
Old 01-10-2010, 01:24 PM   #9
stasis
stasis's Avatar
edit: nm i found the powerstage but all were gone at one pnp will try another tomorrow seeing if the RSR is the culprit today but its rather chilly out and rainy not really wanting to go work on the car in 35 degree rain =P
Old 01-10-2010, 01:40 PM   #10
2manyturbos
A bad radio suppression relay will cause these problems. When the contacts get corroded/burned, the resistance goes way up. High resistance = a lot of heat produced. As heat goes up, so does resistance. IOW, the car will start and run fairly well. Then, as the contacts heat up, the power to the injectors drops resulting in a lean condition. Eventually, there isn't enough power to open the injectors and the car dies. The relay cools off, the process starts all over again. It makes diagnostics a whole lot of fun.
Old 01-10-2010, 02:07 PM   #11
FITZ5
when was the last time you changed the fuel filter.
1998 volvo v70xc awd current project almost done 5000,00 later
1988 volvo744 Ti B230FT stock for now 212,000 miles ice cold A/C-R12 new Garrett turbocharger stock wheels with 205/60/R15 yokohama YK580(still driveable after being rearended. ouch
FITZ5 is offline   Reply With Quote
Old 01-11-2010, 02:30 AM   #12
35 degree rain in west palm?????
Massive airleaks can also cause stumbling and stalling.
Have you tested for spark yet when it's dead?
Old 01-11-2010, 08:28 AM   #13
stasis
stasis's Avatar
tried a couple other RSR's seem to no avail, power stage is my next try, my car is at my gfs house and my tools are limited so im just pulling easy parts to try and then going from there...anyway to check the resistance on a RSR to see if its good? took me 20 min to find mine since it was not on the strut tower and laying down almost on the side of the battery and down on the bottom...
Old 01-11-2010, 01:46 PM   #14
rstarkie
Just pull the radio supression relay and use a piece of wire to make a connection between the two heaviest wires in the plug. With that wire as a jumper if it starts then the relay is at fault for a no start when it is in place.
Randy
Old 01-11-2010, 03:02 PM   #15
Wear a rubber glove and dont touch the car and pull the ignition wire off the ignition coil and have your gf crank the engine. If you see a crisp CONSTANT spark you know the ign is good.
Did we already suggest the crank sensor? That is almost the first thing you should check. Wiggle the wires while gf cranks and see if it starts.
Old 01-11-2010, 03:29 PM   #16
2manyturbos
Yes. Put 12V across the coil connections of the relay to energize it, check the resistance across the other 2 terminals with an ohmmeter. It should be less than 1 ohms if it is in good shape.
Old 01-12-2010, 08:17 PM   #17
stasis
stasis's Avatar
brand new crank position sensor, so i know thats not it...will check rsr tomorrow. any chance its the power stage? just trying to get input payday is thursday and then ill go to town for one last time then takeing it to a shop
Old 01-12-2010, 09:33 PM   #18
2manyturbos
I have never had a powerstage cause these problems, however, a friend of mine that has a Volvo repair business has. The car was a 1991 940 SE. Not that the model matters at all. It would run fine, then wouldn't run at all, yet, if you checked it, the car had spark. The ECU, ICU, crank sensor, injectors and on and on were replaced with know good parts, yet, the problems continued. The car finally got parted out due to the electrical gremlins. The powerstage was put on another car and low and behold, all the symptoms the SE had followed the powerstage to the 93 940 it was installed on. I certainly wouldn't rule out the powerstage as being the culprit on your car.
Old 01-12-2010, 09:43 PM   #19
stasis
stasis's Avatar
thanks for the input went to a new local jy today and noticed that EVERY power stage was removed from the 7's and 9's that were there made me think for a minute...someone came and knew what they were looking for since the ecu and ezk were also missing from every turbo model and other good easy small parts were also missing but at the other local pnp noticed all the power stages intact maybe someone local had the saem problem?
anyway thanks again for the information i really hope it is the power stage local volvo dealership charges 135/hr for labor and im not wanting to pay that but i love my 940 and will pay if i have to
Old 01-13-2010, 11:10 AM   #20
Have you done the wiggle test to the RPM sensor wiring yet?
Dont pay Volvo a penny. Do it yourself! Powerstage is two bolts and RPM sensor is one bolt.
Old 01-14-2010, 11:06 AM   #21
stasis
stasis's Avatar
fianlly found a powerstage searched 3 jys and 18 7/9's all were gone except for one! must be a common part to fail or expensive is all i can figure...any way part number is 0 227 100 124 i hope its compatable else im screwed and have to buy a new one
EDIT: what luck its the same part number, considering it came off an N/A 87 740...wish me luck on the trial and i hope it works!
Old 01-14-2010, 12:00 PM   #22
stasis
stasis's Avatar
nope....nada battery is just about dead now for trying to crank it up for a few days and trying new sensors....last thing i can think of is the coil maybe its going bad? dunno gettin a AAA membership today and having them tow it back to my house where i have all my tools at my disposal and not just working with a socket set =P ....
Old 01-14-2010, 12:54 PM   #23
You need to check for voltage switching at the coil when cranking. This will tell you if you are getting an RPM signal.
Old 01-14-2010, 10:34 PM   #24
stasis
stasis's Avatar
you think a brand new sensor would be bad? rpm signal comes from the CPS yeah?
Old 01-14-2010, 11:29 PM   #25
SATAN
SATAN's Avatar
I seem 2 be having same issue!! Runs well 4 couple hours then stops. 20mins later i can drive again. I just replaced my crank senser but still no show. I've noticed my a/c button flashes when this hapns??? Let me know how you go cause yes 'volvo mech's' are getn rich..
SATAN is offline   Reply With Quote
