Old 02-03-2010, 11:14 AM   #1
JERIC
Default 93 245 overdrive
My newly purchased 93 245s overdrive was working then on the ride home today it didnt shift into overdrive is this common and is there an easy fix for it? It is anb automatic.
Thanks
Eric
JERIC is offline   Reply With Quote
Old 02-03-2010, 12:00 PM   #2
1Smooth84
1Smooth84's Avatar
Say hello to my little friend.
http://www.ipdusa.com/Volvo-200/Tran...-266-672-1891/
1984 245 w/TT-1JZ-Primer Grey
1989 245 w/1JZ VVTI Maroon
1991 245 Stock Auto-Gold
1991 245 Stock 5-Speed-White 2JZ VVT-I Swap coming Soon
1Smooth84 is offline   Reply With Quote
Old 02-03-2010, 12:03 PM   #3
vvpete
There can be a few reasons that the OD doesn't work. Dirty trans fluid and clogged valve orifice, bad OD solenoid, bad OD solenoid wiring, bad switch, bad relay, or blown fuse. If you hear a click under the car when you press the switch, then it is most likely old dirty fluid and the hydraulic pressure is too low to engage the OD. How does the fluid look?
If the solenoid is bad the by-pass kit is a good idea, but limits the gearing possible. It's nice to have it on all the time as it helps when in low gears for round-town driving mileage
vvpete is offline   Reply With Quote
Old 02-03-2010, 12:12 PM   #4
Flying Jester
I hear 240 OD solenoids are really super twitchy. The perfect fix would be an M47 5-Speed, though.
Flying Jester is offline   Reply With Quote
Old 02-03-2010, 01:29 PM   #5
JERIC
this is my new DD already have my 142 for doing fun stuff to.
The fluid does need to be changed will do that 2marow after work and see what happens.
Thanks for the info
Eric
Old 02-03-2010, 01:52 PM   #6
Three Fat Tigers
Three Fat Tigers's Avatar
Location: ↓ Lynchburg, VA →| '89 740Ti | '90 760Ti | '92 240 | '94 940T | '96 960 | '96 M1
As stated above, park the car in a quiet location and listen at ground level (lean over as far as you can with the door open), you should be able to hear the solenoid clicking when pressing the shifter button (ignition on). Don't confuse this for the clicking from inside the dash where the OD relay is located. If you hear the clicking under the car, odds are the relay and solenoid are good. Make sure fuse #11 is in good order.
Otherwise the most common failure is with the relay. On your model, even if the dash light comes on when you press the button, the relay could well still be faulty. Best to pull it, pop the cover off and inspect the circuit board for any cold-cracked-failed-fried solder joints, re-flow as need or all of them. Access the relay by removing the glove box, relay is located below the center dash vents. If the relay is in good order, check under the car, use a test lamp to make sure there is both sufficient voltage and current reaching the solenoid connector; and if so, odds are you need a new solenoid. I'd pull it off and bench test it.
If replacing the solenoid: The same OD solenoid is used on most all automatic equipped '82+ 240/700/940 4 cylinder cars, so you might be able to find a good used one, but otherwise about 60$ for a new aftermarket. Jack up the entire driver's side of the car, clean the area around the solenoid first with brake cleaner to minimize dirt contamination, be ready for some fluid leaking out, but it shouldn't be too much. Two 12mm bolts, flex head ratcheting gear wrench works best.
For additional reference:
http://www.threefattigers.com/Protoc...ODsolenoid.htm
Note the insulation on the white wire that exits the shifter is a common failure point where the insulation fails and the wire shorts, damaging the relay.
On an automatic? Still not going to shift into OD until about 35 mph.
93 240 manual was an M47. 240 automatic OD solenoid is the same as found on almost all 4 cylinder RWD automatics, not a part I would describe a twitchy though.
Three Fat Tigers is offline   Reply With Quote
Old 06-10-2010, 03:46 PM   #7
growley
has a large member
growley's Avatar
Hey guys,
I know this thread is old, but I'm having a non-working OD issue as well on my '91 240. It suddenly stopped working today.
I went to take it out on the highway this morning when I realized that it wasn't shifting into OD. I later stopped and restarted the car and the arrow on the dash was lit for about a minute after I started the car, after which it turned off, with the OD still not working. I just replaced the OD relay with a brand new, OEM one and now the light on the dash stays lit constantly and the OD still doesn't work. I checked the fuse with a test light and it seems to be fine.
I've read others on here say that arrow lit on dash+no OD= relay failure, but that didn't fix it for me. Any other suggestions?
-Ian
'91 240-"slolvo"
Gnargineering
growley is offline   Reply With Quote
Old 06-11-2010, 10:03 AM   #8
growley
has a large member
growley's Avatar
Anyone?
Old 06-11-2010, 10:28 AM   #9
Ian A
Ian A's Avatar
Originally Posted by growley View Post
Hey guys,
Maybe the switch is toast? Or as suggested a few posts up the wire going from the shifter to to the trans tunnel might have a bare spot that is shorting?
Ian A is offline   Reply With Quote
Old 06-11-2010, 10:34 AM   #10
growley
has a large member
growley's Avatar
I was considering the switch as well. I also need to check out the solenoid and wiring.
Old 06-11-2010, 02:48 PM   #11
growley
has a large member
growley's Avatar
Well I just got done driving my car again and the OD works now But I'm still pursuing the culprit. Perhaps a short in some wiring?
Old 06-11-2010, 03:21 PM   #12
Ian A
Ian A's Avatar
I need to replace the solenoid on mine, but I can't get a wrench around the bolt closest to the front of the car, 12 point flex line wrench won't grab it.
