Old 02-05-2010, 08:29 AM   #1
745wagon
745wagon's Avatar
Default Oil Filters-Best brand?
Need to change my oil, 1990 745, But don't have access to my dads shop where i used always either Mann or Volvo filters. Anything out there comparable? I've heard good things actually about the Napa Gold line of filters.
Thanks
Gold 1987 745-435,601-Gone but not forgotten
Red 1993 850 GLT, 410,xxx-Gone for good, i hate you
Gold 1990 745 280,000 New whip- Solid reliable DD, wanting a 5 speed swap and hydras
745wagon is offline   Reply With Quote
Old 02-05-2010, 08:39 AM   #2
Three Fat Tigers
Three Fat Tigers's Avatar
Location: ↓ Lynchburg, VA →| '89 740Ti | '90 760Ti | '92 240 | '94 940T | '96 960 | '96 M1
fram it! http://www.youtube.com/watch?v=CUMP3-H3eyc
Three Fat Tigers is offline   Reply With Quote
Old 02-05-2010, 08:41 AM   #3
fengler
fengler's Avatar
I think napa gold uses wix filters, which is a good brand.
Current-2006 Toyota Highlander Hybrid (190k)
Current-1967 Volvo P1800
Fengler would totally smash.
Originally Posted by regina745ti View Post
lext nevel hengler maneuver
Originally Posted by resa850
Nick: I love you.
Originally Posted by CaptainLeah View Post
I saw fengler was the OP and I knew it was going to be gold.
"Without music, life would be a mistake." - Nietzsche
fengler is offline   Reply With Quote
Old 02-05-2010, 08:44 AM   #4
740Weapon
Traitor
740Weapon's Avatar
mobil 1 filters are great, probably better than mann based on my subjective oil-life by color rating, but they dont fit turbo models.
'90 744 16 Valve. 16.317@85.55. Sold.
'92 244. Sold. http://pbase.com/740weapon
Old 02-05-2010, 08:47 AM   #5
745wagon
745wagon's Avatar
Mine's a non turbo, I didn't know there were different filters for turbo ones. Learn something everyday!
Thanks, Gunna grab a napa gold and giver a shot.
Old 02-05-2010, 08:51 AM   #6
German made Mann
Old 02-05-2010, 08:55 AM   #7
unxetas
Mann, Napa Gold or Mobil 1 apparently..
90 745 16v - +T wasn't meant to be. m46, sways, IPD springs, Bilstein HD's and big ass RA1's
89 745 Turbo - auto , sways, IPD springs, Bilstein HD's.. e-codes!
(83 242TI - LeMons!) RIP
unxetas is offline   Reply With Quote
Old 02-05-2010, 09:00 AM   #8
740Weapon
Traitor
740Weapon's Avatar
there aren't supposed to be, but the M1 filters are too long for a turbo model because mobil didn't do enough leg work.
Old 02-05-2010, 09:06 AM   #9
ErikS
FWD!
ErikS's Avatar
K&N oil filters have better flow rates and larger filter surface areas than Mann and Mobil 1.
'95 854 T5M
'15 MB ML350
'15 F150 3.5 Ecoboost
ErikS is offline   Reply With Quote
Old 02-05-2010, 09:18 AM   #10
colgate41
colgate41's Avatar
As long as you are changing your oil on the regular then it really dosent matter. I feel like they all do the job well. That said...any oil filter that is left in there for 4-7000 miles will suck. So just change your oil and you will be fine.
1991 744 Turbo. Last Volvo left.
colgate41 is offline   Reply With Quote
Old 02-05-2010, 09:23 AM   #11
Then there's that little issue of check valve opening pressure.
I'll stick with OEM thank you please.
Old 02-05-2010, 09:34 AM   #12
Three Fat Tigers
WTF? Same Volvo/Mann filter used for turbo and na alike, same story where the M1 filter is concerned.
For reference this↓ is a photo of the Bosch M1-109 filter attached to a '94 944T.
http://www.threefattigers.com/Protoc...P940_3771b.jpg
In order of preference:
Mobile 1
Mann/Volvo
Pure 1/Bosch Premium
Old 02-05-2010, 10:13 AM   #13
impulse922
the newer fram filters actually aren't that bad. Its just the el cheapo orange ones you want to avoid.
I use mahles in my s60, but besides that the other cars in my family get what ever filter of decent quality that is on sale with the oil. Pureone from AAP, k&n, mobil 1, or the better frams.
-Matt
'90 780 and '03 s60 T5M
impulse922 is offline   Reply With Quote
Old 02-05-2010, 10:45 AM   #14
triode52
Default mann or genuine volvo
The standard oil change interval specified by volvo for the B230 powered volvos is 5000 miles. Since most of us probably stick to the 3000 mile rule it probably does not matter within reason what you use, which is especially true if you use synthetic oil. However, as others have mentioned the Genuine Volvo and Mann filters have the best check valves and given that these probably have more of an impact on protecting the engine than the actual filter medium I stick to those. If you have to do a boutique or aftermarket filter I would roll with mobil 1 or NAPA Gold as mentioned earlier.
Mike
triode52 is offline   Reply With Quote
Old 02-05-2010, 10:55 AM   #15
fidel
knox motorsports
fidel's Avatar
you might find this interesting
http://minimopar.knizefamily.net/oilfilters/index.html
http://minimopar.knizefamily.net/oil...ce.html#mobil1
its a shame that there isn't mann or mahle filters in the comparison .
fidel is offline   Reply With Quote
Old 02-05-2010, 10:58 AM   #16
SL8Brick
yea, I'm THAT guy
SL8Brick's Avatar
thin wallet oil change = SuperTech ST16(yes, I am one of the "people of Wal*Mart")
1993 240 Wagon - 326k miles
1999 Audi A6 Avant 2.8 Quattro - 134k miles
SL8Brick is offline   Reply With Quote
Old 02-05-2010, 11:02 AM   #17
DrvSfly
Bored Clown
DrvSfly's Avatar
I just hope that they put your oil drain plug back in AND tighten it.
Spend the extra buck and get a decent one.
Drive Safely
I think we'll either get rid of religion, or it will get rid of us.
'83 245 TIc sold
'97 960 totalled
'94 745 totalled (not mine)
'87 744 totalled (not mine)
'91 780 totalled and sold
'81 b21f, T cam, Lh2.2, 960 injectors, junkyard/back of the shop 15" trash rims. - Sold
DrvSfly is offline   Reply With Quote
Old 02-05-2010, 11:09 AM   #18
impulse922
whoops, forgot Bosch which appears to be a top performer
Old 02-05-2010, 11:13 AM   #19
fisky52688
broken down 240
fisky52688's Avatar
what about MANN filters
1987 244. Will be B23 powered one day.
fisky52688 is offline   Reply With Quote
Old 02-05-2010, 11:16 AM   #20
MrBill
fige=500Dollar Mistake
MrBill's Avatar
yeah I've been doing the bosch filters for a while on the cars that matter to me. Just recently started using the supertech filter for the dd
Someone say crazy rays?
Old 02-05-2010, 11:21 AM   #21
CEHepp
FWDFTW
CEHepp's Avatar
There are very very few filters I recommend.
Mann, of course.
Purolator PureONE filters.
Bosch is one of my personal favorites.
Mobil1 is also good but damn expensive.
DD: 2004 S60 on copper Pegs
Current project: 2004 V70 T5M
CEHepp is offline   Reply With Quote
Old 02-05-2010, 11:40 AM   #22
1970_Volvo_142S
The best thing to do is buy a case of 10 Mann oil filters from FCP Groton and you're paying $3.49 a filter for the same company that makes the $20 Volvo filters from the dealership. The same filter fits my '70 142 with a B20, my wife's '85 744 turbo and my '92 745 turbo. Why mess around with anything else? just my opinion.
85 744T IPD cam, ultimate wastegate, 3" DP>2.5" Magnaflo Mufflers, KYB Excel in all 4 corners, Cherry Turbo Upper and Lower Braces, IPD sways, Powdercoated Virgos, Tracey's Ride
1970_Volvo_142S is offline   Reply With Quote
Old 02-05-2010, 12:10 PM   #23
745wagon
745wagon's Avatar
Mann, of course.
I had a Purolator filter on my old 740 and did not like it. I used the same oil i always use, (Castrol 1540) and i was about 2500 Kms from my 5k oilchange interval and my oil light started flickering, It was clogged. The oil in that car after 5000k with a Mann filter came out CLEAN always. Just i could have had a bad experience?
Anyways, Picked up a napa gold filter, like $7 so i'm happy with that. Good to see all the brands that Tb approves of for next time.
Old 02-05-2010, 12:34 PM   #24
Three Fat Tigers
Bosch Premium is supposed to be the same thing as the Pure 1, I've used the Bosch P. with no issues. I used to use Amsoil filters until I had problems with the check valve drain, too expensive a filter to put up with such defects.
Note that color of oil is not really a factor of the filter used but of how long the car is driven, lots of short trips, and or lots of stop and go will tend to make it darker quicker.
Old 02-05-2010, 01:52 PM   #25
woodenshoes
woodenshoes's Avatar
+1. Same here, 3,740's and 2, 240's from 78-90 all the same. Simple, cheap, and OEM....
woodenshoes is offline   Reply With Quote
