Old 02-05-2010, 12:32 PM   #1
Boost
Boost's Avatar
Default Removing dashboard, 85 244
Im gutting the interior today. I got to the dashboard, and im having some trouble. If there is a detailed write up, or an online manual, please, would you point me in that direction??
Thanks guys
Boost is offline   Reply With Quote
Old 02-05-2010, 12:37 PM   #2
Three Fat Tigers
Three Fat Tigers's Avatar
Location: ↓ Lynchburg, VA →| '89 740Ti | '90 760Ti | '92 240 | '94 940T | '96 960 | '96 M1
Don't know of a write up, but can say it's super easy, should be able to get it out in under 30 min.
Three Fat Tigers is offline   Reply With Quote
Old 02-05-2010, 01:05 PM   #3
Boost
Boost's Avatar
I got it out, and youre right! That was super easy. Lock the thread
Old 02-05-2010, 01:36 PM   #4
Boost
Boost's Avatar
Oh one more question guys... Im pulling a dash from a 92, they use Torx screws. What sizes will I need?
Old 02-05-2010, 05:05 PM   #5
fcpgroton
fcpgroton's Avatar
I think it is T-20.
OP, you should do a write up or at least take some pictures of how you removed it.
FCP Online Support Team
FCP Euro - European Car Parts Specialists
FCP Import - Import Replacement Car Parts
fcpgroton is offline   Reply With Quote
Old 02-05-2010, 06:34 PM   #6
Boost
Boost's Avatar
Originally Posted by fcpgroton View Post
I think it is T-20.
Alrighty, I'll try and take some more pix tomorrow, and I may try to make a small write-up
Old 02-05-2010, 11:23 PM   #7
egads
n00b
egads's Avatar
Write ups rule :-)
egads is offline   Reply With Quote
Old 02-06-2010, 08:12 AM   #8
SwedishBee
Drill em deep
SwedishBee's Avatar
make sure you use the steering column cover and driver side kick panel (duh) with the 92 dash..
your 85 stuff wont work...
I just pulled a 92 dash myself and I spent some time test fitting which parts I would need.
You need the column cover and underdash panely thing.
The column cover wraps around the ignition switch different...
and the thin kick panels on the sides, you can use the ones from your car... The 92 panels are cut down, but they are the same... Im not sure if you do indeed need to cut them down, but just saying.
I still havent installed mine into the 81 yet, so does anyone else have any advice on installing a newer dash into a old car?
I know Im ganna have to make some kind of bracket to hold on the big bulky underdash panel
Originally Posted by CrazyChopStick View Post
I bought an 850.
SwedishBee is offline   Reply With Quote
Old 02-06-2010, 08:29 AM   #9
Three Fat Tigers
Yes I've very recently put a '92 244 SRS dash into an '84 242Ti. As said before the steering column covers must the SRS type and you do need to install and use the knee bolster, and the left kick panel is different. As for or the center dash console, only the left metal support leg and side panel need to be updated to the SRS type, this to accommodate the right support bracket for the horizontal bar that makes up the bottom support for the knee bolster. The left side support for this bar is provided by the new type (SRS) hood release handle bracket, this you can do without by just fabricating a simple bracket to hold that side of the bar. The new type hood release is much better to have with the knee bolster but you can live with the original type release. Other than that, every thing bolts in the same way.
Old 02-06-2010, 10:20 AM   #10
Mr. V
Mr. V's Avatar
link ...
http://volvo2.homestead.com/dash.html
Old 02-06-2010, 11:31 AM   #11
slow240
Home Schooled
slow240's Avatar
i did this with the help of a haynes manual (sarcasm)
these were the directions for changing the heater core:
"step 1: remove dash
step 2: separate blower halves
step 3: remove heater core
installation is the reverse of removal"
and there was NO clarification on how to remove the dash, and 4 hours later, i had a fresh heater core!
