Old 06-25-2013, 05:30 PM   #176
Andreas
Andreas's Avatar
out of the vakum plastic, all the stripes is left over epoxy that we`ll sand of tomorow. and then coat the carbon With a coting that gives a smoth surface
My build..
cars: Audi A8 W12 6.0, 89 Audi V8 3,6 quattro, 89 Audi V8 4,2 twinturbo quattro, 79 volvo 242, Honda Cbr Fireblade
Andreas is offline   Reply With Quote
Old 06-25-2013, 05:32 PM   #177
boosted12a
weapon of mass detonation
boosted12a's Avatar
is that all carbon or is it the original covered?
91 940 SE, 119K, GOLD
05 S80 2.5T, RED
09 XC70 3.2L wifes gas sucking DD, BLUE
04 GTI VR6 (6 gears of fun) Silver
85 RX-7 GSL SE(efi'ed), BLACK
76 Suzuki RE5, BLACK
07 Suzuki SV1000S, BLACK, but turing white slowly
Old 06-25-2013, 05:40 PM   #178
Andreas
Andreas's Avatar
its all carbon, its less then 1 kg :P
but its casted on a mold made partly out of a original dash
Old 06-26-2013, 05:16 PM   #179
Andreas
Andreas's Avatar
btw, i have a friend that have a RX7 like Yours :P With a 12a turbo, i dont remember exactly but it has somewhere around 650 hp
Old 08-22-2013, 03:50 PM   #180
Andreas
Andreas's Avatar
back on the track With the widebody benz again :P (i am the passenger)
http://www.youtube.com/watch?v=9ZAyr2ZH_AE
Old 08-22-2013, 03:52 PM   #181
Andreas
Andreas's Avatar
ok, so i could make a short post i see..
trying to make an update here, but i just get an stupid 403 error!!
Old 08-23-2013, 03:48 AM   #182
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
What a great Racetrack.. I love Tracks with Elevation in them..
Old 08-23-2013, 10:08 AM   #183
Andreas
Andreas's Avatar
picked up the head yesterday its been ported, New valve guids, New double valve springs that can handle 14mm lift and a lot more rpm, lighter retainers, valve buckets and shim instead of the hydraulic crap, New cams 275 degree, 11,5 mm lift!
Old 08-23-2013, 10:08 AM   #184
Andreas
Andreas's Avatar
Old 08-23-2013, 10:08 AM   #185
Andreas
Andreas's Avatar
Old 08-23-2013, 10:08 AM   #186
Andreas
Andreas's Avatar
since my ARP head stud kit was missing the lube, i just finger thight a few bolts and threw on some stuff to see it more Complete again
Old 08-23-2013, 04:34 PM   #187
pwschuh
Rolling...
Secksay.
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe
Old 08-23-2013, 09:43 PM   #188
stevE85
Formerly 1983_242
stevE85's Avatar
Looks awesome! What kind of power are you after? The head looks like it should move some air. :-)
1983 242: 11:1CR B23/M46/3:73's 121WHP DD'er
1982 244-Build Thread Here
stevE85 is offline   Reply With Quote
Old 08-24-2013, 04:04 AM   #189
Andreas
Andreas's Avatar
im happy if it makes around 700-750 hp
Old 08-24-2013, 04:08 AM   #190
What buckets/lifters do you have? Im always listening for info on what can be used to replace the hydraulic ones. When I was running 16v I always had problems with the hydraulic ones and also with floating valves due to weak springs or sticky valves. Both caused misfire issues.
Old 08-24-2013, 04:45 AM   #191
Andreas
Andreas's Avatar
they are from a volvo 360 :P
Old 08-24-2013, 04:47 AM   #192
340GLT
340GLT's Avatar
Andreas do you mean volvo 340?
Adam
F559 LFE - 340R T5 in progress
C208 CTR - 340 1.8 16v
D300 LBO - 360 GLT 3 Door Turbo project!! (and restoration)
340GLT is offline   Reply With Quote
Old 08-24-2013, 10:41 AM   #193
Andreas
Andreas's Avatar
Adam
thats probably correct the Renault powerd one, b17 i think
Old 08-25-2013, 02:39 PM   #194
Andreas
Andreas's Avatar
so, tourqed Down the head today, and started planning a way heat the engine to 90*c so i can retourqe the head studs to spec! and i think i have a plan with a waterpump and a 6kw heater from a swiming pool :P
i also mounted a oil cooler and adapted a fan on the cooler (honda cbr 1000 fan)
Old 08-25-2013, 02:47 PM   #195
spourcyrous
Location: Los Angeles, CA (SGV); Chicago, IL; San Diego, CA; SF Bay Area, CA
This is an awesome build. That w124 also......
1992 Volvo 245 Euro spec'd
1991 BMW 318i E30 M42B18
1983 Peugeot 505 STI
spourcyrous is offline   Reply With Quote
Old 08-27-2013, 05:24 AM   #196
340GLT
340GLT's Avatar
Yeh i have a set of these sat in my parts drawer for a 16v head i dont own yet...haha
Yeh volvo 340 B172K.
Build is looking great!
Adam
Old 09-01-2013, 04:25 PM   #197
Andreas
Andreas's Avatar
water pump innlet is sealed, just need to get a m22 1,5 plugg to seal the hole from the pump to the head now and its ready for water
made a vakume "rail" so the Map sensor reads from all 4 sylinders to!
Old 09-01-2013, 04:27 PM   #198
Andreas
Andreas's Avatar
and got myself a Nice flywheels sensor! just need to drill and tap a hole!
Old 09-01-2013, 04:42 PM   #199
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
moa... awesome
Old 09-03-2013, 11:27 PM   #200
shaved240
shaved240's Avatar
