Old 09-30-2014, 11:56 PM   #1
skuhn117
skuhn117's Avatar
Default 92 240 wagon vibration please help
So I have been attempting to chase down this problem for the last month or so and I am throwing in the towel. I can find threads with similar issues but nothing to the T or that answers the problem, closest I have come is this thread http://forums.turbobricks.com/showth...bration&page=2
1992 240 wagon
when braking from speeds >or= to 30mph there is an intense judder/shaking/vibration that feels like it is coming from the rear of the car, no vibration in the pedal or steering wheel. Almost feels as if the entire drivetrain is shaking. Also there is a finer vibration throughout the car when I accelerate and reach almost exactly 30mph and goes away @ > 35mph. This goes away if thrown into neutral. Also when braking @ > 30mph with just the hand brake there is no juddering. So when driving 30mph+ and applying the brake there is an awful shaking/juddering/vibration that goes away when speeds get down to 20mph. Any ideas?
What I've gone through so far:
Torque rod bushings replaced
Tranny mount replaced
engine mounts are solid
rotors and pads have been checked(I feel like if they were warped I'd feel something in the pedal?)
Just looking for an idea what to check next or if anyone has had this same problem. Thanks
skuhn117 is offline   Reply With Quote
Old 10-01-2014, 12:37 AM   #2
Three Fat Tigers
Three Fat Tigers's Avatar
Location: ↓ Lynchburg, VA →| '89 740Ti | '90 760Ti | '92 240 | '94 940T | '96 960 | '96 M1
Have you inspected the diff pinion shaft for play, possible bearing failure? Same for trans output shaft, and the u-joints.
Three Fat Tigers is offline   Reply With Quote
Old 10-01-2014, 12:45 AM   #3
centason
Knipex=welfare queen
centason's Avatar
Did you look at the trailing arm bushings? Also the above is something to check as well. Center shaft bearing, donut, and spring.
Member: TBCCS
"People will believe a big lie sooner than a little one, and if you repeat it frequently enough, people will sooner or later believe it." -Walter Langer
Old 10-01-2014, 11:56 AM   #4
DoubleBit
Sure sounds like warped/hard spotted rear brake rotors to me. BTW, the parking brake applies a small set of brake shoes not the rear disc pads, so that really doesn't rule out the rotors/pads being your problem. I haven't seen too many problems with volvo rotors, especially the rears. Only one memory of that and it was a car that sat a while, had rusty rotors and as the rust wore away the spot where the pads had rested and held extra moisture to deepen the rust became very hard and caused a nasty vibration like you are describing.
Fear not! God has a plan and you are part of it!
DoubleBit is offline   Reply With Quote
Old 10-01-2014, 11:23 PM   #5
theknave
theknave's Avatar
I'm with DoubleBit.
I'd still check your rotors against specs before throwing in more parts, especially if this is something that has developed slowly over time. Run-out is measured in thousandths of an inch, with most manufacturers' specs allowing less than a hundredth, IIRC.
theknave is offline   Reply With Quote
Old 10-01-2014, 11:34 PM   #6
Pro Sneaker Peddler
Holy **** you're back.
