Finally fixed the 740 clutch master
So this morning santa clause stopped by in his big white purple and orange sleigh...
I was determined to make this clutch master work, since:
A) a 260 MC was more than I wanted to spend
B) I got this one for $10 and
C) upon dissasembly all the seals were in great condition and the bore blemish free.
Originally the plan was to cut off the stock plastic clevis and weld on a bolt with the head cut off, but I couldn't find any pass through style clevises that were narrow enough for the space alloted.
Then, after I found this male end clevis, i figured I'd get my buddy to weld on a piece of threaded tube, but Summit didn't have any, so this rod end, was substituted. And I didn't feel like waiting, so I simply cut threads on the end of the stock pushrod and BAM!
The one thing I would change next time is to cut a bellow the second "lip" on the stock rod, this would provide a wider range of adjustment. As it sits I had to trim about 1" from the clevis and there isn't much adjustment left to go shorter; But considering the whole point was to get the pedal off the floor, I'm not too concerned.
Installed.
I also trimmed about 2 square inches of material from outer edge of the pedal assembly...with a hacksaw...upside down. That way I can put the pin through from the outside and not have to worry about the cotter pin getting hung up.
