speedn_j
Banned
- Sep 5, 2005
- bakersfield, ca
Everything I've used leaks. I don't want to use liquid gasket maker but I'm pretty close. What do you guys use?
Paper valve cover gasket from wherever, plus a very thin smear of permatex ultra black on each surface (after it has been meticulously cleaned, and with the usual extra fat gobs of sealant in the elbows of the round humps near the front and rear seals)
edit: and by very thin smear I mean almost transparent thin, except in the spots mentioned above and in VB242's post
That's what I been doing..with the paper gasket how do you loosen it up so it can flex without cracking?
OE Volvo is the only way to go for the valve cover gasket. Most of the other gasket types will leak immediately, or, very soon after installing them, unless you glue every bit of both sides of the gasket. They are 2 to 3 times the price for OE, yet, worth it not to go back in to fix a leak.
