I let my friend borrow my 91 240. He said that after he started the car 2 minutes later, it sounded like something industrial, like someone blowing leaves after he started it. He said that it gradually went away after 3 or 4 minutes. He wasn't sure if it was someone doing landscaping, or something else (can't hear that well).
After shutting the car off at the store, and then attempting to start it, the lights on the instrument cluster came on, cd player worked. The battery had 12.75 volts on the off position. The fuel relay was clicking and I could hear the fuel pumps engaging. All fuses were good as well.
There was no sound whatsoever of starter engagement when turning the key. It was as if one was attempting to start the car with the battery disconnected.
Eventually, we got it started by pushing it and popping the clutch; it ran fine.
Do I need a new starter, or is it something else like an ignition switch?
I'm thinking that I do, but I would like to verify that it is the starter in order to keep the costs down.
Thanks for all of your help with this debacle in advance!
