- Stock PSI Or Bust -
- Mar 23, 2007
- Ocean Beach S.F.
I wouldn't change anything that still looks good because most aftermarket stuff is crap and it will be a lot of work for a big step backwards.
How are the front wheel bearings? Mine were loose and caused some instability, tightened em up all better now.
CAM style rack is my guess. Have almost the same setup with my wagon.....23mm front sway Stock rear swaybar. Coil and a half off the front....none off the rear. Bushings...wheel bearings.....ball joints....struts etc all in good order.
Just returned from a 500 mile trip to Austin and while it was windy I still found myself having to keep making inputs to the steering wheel. Have a ZF rack from philski that I need to bolt in that I believe will remedy my issues.
It is yes, lowered 35mm ish front and nothing YET in rearend. Im not expert at the area as you can hear, i only know stuff about engines ^^
Funny thing is, that when not accelerating hard, its running pretty steady even at 60 mph + when it is NOT windy. So im guessing rear end might be a little worn out.. Must be, considering that everything at the front is new, and upgraded with strut reinforcement, and bars under engine to stiffen too.
